SOURCE: Hi, we have aa Saecco
Possible areas are the steam valve leaking or the boiler valve housing is leaking. I suggest Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : [email protected]
SOURCE: cuisinart EM-200 espresso machine won't make coffee
you might check the water hose and make sure that it didn't come disconected. sometime they wear out over time and strech becoming loos. and when that happens the maker can not **** the water through the tube into the expressor mix causeing it to make u sucking noise.
SOURCE: Cuisinart EM 200
I was about to abndon pods on this machine, and then I actually used the Pod filter basket - it worked like a charm. Decalcifying is not a bad idea.
SOURCE: Gaggia Classic Espresso Machine - will not pump water
Hi, this is so easy to fix. Firtsly unplug the machine. Then remove the two screws in the top plate so that you can have access to the internals of the machine. You will see the red pump to the left hand side at the back. Remove the two screws that hold the pump in place (use a magnetic screwdriver so that you can pull the screws out). Pull the pump up towards you and then unscrew the thin plastic pipe at the top of the pump . It is the pump that has the scale build up problem. If you the put the water tubes into the water tank and hold a cup to the top of the pump to catch the water you then have to switch the pump on. You will then start to see lots of scale come out of it and the pump will pump more water than you are expecting so be careful. Be sure to cover the internals of the machine whilst you are doing this as you don't want to get water on the electrics and electricute yourself!!! Then rebuild it! Just svaed yourself £100 in having it serviced :-)
SOURCE: Krups XP2070 coffee machine -
This will most likely happen when the pressure valves become defective. Replacing the two valves (they come in pairs) should fix the problem.
