How do I Copy my contact from Modile to Laptop, Itried with active Syn but I was unable , Even I cannnot play the Song due to windows File error, Please Help
MP3 players can only play music files in mp3 file format.
You can download mp3 music files onto your computer and then copy them to your MP3 player.
For CD disks you need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player. You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format:-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
1. Locate the actual song file. You can check this in iTunes, use the 'Get info' command, in the summary tab, there's a 'where' item at the bottom. Mentally note that this is 'file#1'.
2. Once you've find the file, make a copy of this file in some other folder. Or maybe even on the desktop. Mentally note that this is 'file#2', which is a copy of 'file#1'. Do not rename.
3. Go to iTunes, and delete the problematic song. If iTunes ask to remove the file, click 'yes'. If iTunes doesn't ask, manually remove the file from the original folder. You are removing 'file#1'.
4. Once this is done, move back the copied file, ie 'file#2', to location where 'file#1' was.
5. Add the song back into iTunes. iTunes will treat it as a new song. You will lose some data like Rating or Play Count. You might need to add some details like track number and so on.
6. Sync your iPod. Done.
You have to do this steps to every problematic song. Tedious, yes. But it's better than the need to re-encode the files.
Microsoft Windows Media Player is a free media player software that comes with the personal computer version of Windows operating systems. The software supports basic file formats such as WMV, WMA, AVI, MP3, and ASF. The player included in Windows XP gives you the power to create your own CDs, search and organize digital media on your PC, and copy files to portable devices such as CDs and pen drives. Fix Windows Media Player Problems Corrupted and missing DLLs files, incorrect registry entries, and outdated files are some of the causes of Windows Media Player errors. Covered here are a few steps that you can take to fix common problems. C00D11CD: Unknown Error C00D11CD errors occur when an operating system component or some other program encounters an error and does not communicate it to Windows Media Player. Due to its generic nature and multiple reasons for occurrence, there is no specific solution to this problem. If you encounter the error when trying to play an AVI or MPEG 2 file, then most likely, you do not have the correct codec version installed on your system. To fix a Windows Media Player problem related to codec, search for the required codec on the Internet, download it, and update it on your system to play the required file. Windows Media Player uses Digital Rights Management (DRM) to authorize copying files to a CD or to download them from an online music store. If you do not have DRM authority to copy a particular song, you will not be able to play it and the error will pop up. Windows Media Player uses the wmadmoe.dll file to encode files. If something goes wrong with this file, you may get the c00d11cd error when you try to copy songs from a CD to your hard disk. To fix a Windows Media Player problem in this situation, you must register the DLL file by running the command ‘regsvr32 wmadmoe.dll’. 80040155: Interface Not Registered If this error occurs when you try to burn songs into a CD, then the most probable cause is that the required player files are no longer registered on your system. To fix this error, try to reinstall your Windows Media Player or download and install a newer version of the player, if available on the internet. 800C2EE2: Action timed out This error occurs when your Windows Media Player is unable to connect to a server due to problem in the network, and therefore cannot play protected audio/video files that you download from an online music store. Incorrect Internet Explorer security settings might be the cause of this problem. To fix this, open Internet Explorer and select Tools-Internet Options-LAN Settings. Next, clear the Automatically detect settings check box. C00D0FAA: Cannot rip the files The error usually occurs when you try to rip CDs to MP3 format. Existence of entries from an earlier player version in the registry might be the reason behind this problem. One way to fix this problem is by adjusting the audio quality. However, if you want to maintain the audio quality, then to fix this Windows Media Player problem, open the Registry Editor by running the Regedit command and navigate to the subkey given below. HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MediaPlayer\Sett ings\MP3Encoding Here, open ‘LowrateSample’ and delete the value displayed in the Value Data box. Select OK and exit Registry Editor. Many times errors also occur when there are corrupt files on the system or there are invalid DLL entries and other related incorrect entries in the system registry. For this, you must try to download reliable registry cleaner software from the Internet and scan your registry for invalid entries. Using registry cleaner software, you can easily and efficiently fix Windows registry problems, and make your PC free from irritating errors. Errors can occur in Windows Media Player due to outdated files, missing or corrupt DLL files and incorrect registry entries. Most of the time, you can fix Windows Media Player problems by updating missing files or by upgrading the player to a later version. Additionally, to prevent registry-related problems, you can use a registry cleaner software to regularly scan the registry and eliminate invalid DLL entries and corrupt values from it.
Mr Dinesh
REM file extension appears when media files are saved to device memory and are not removed when the media file is transferred to a computer.
You cant change this..after transferring the media file to the computer, rename the file to remove the .rem extension.
Hi, Please check with the another disk if the same issue is coming with different disks this is a ODD issue otherwise the disk is faulty as cyclic redundancy means the data could not red from the sector of the disk. Thanks
Uninstall the sound drivers from device manager, then reboot. It will find the sound devices and reinstall the drivers, then you may need to adjust the sound settings.
