I have computer 4600c dell wich does not have dvd drive only floppy disk hard drive is new not windows and i just purcharse on cd rom from ebay that fit my computer , also i have dvd drive usb conection that is not reconized byt the pc so i try to boot from any of those drives cd or floppy and show this message bootmgr missing , them i check that IDE Drive Diagnostics and show cd- rom not supported , i try to load windows from another computer moving on this hard drive them putting back not work anyone will help me with this one
You might have to go to the BIOS of your computer to ensure your drive is recognised. Once it shows there, make sure you change the Drive as your first boot device.
Thanks
Ranjit
www.supportminds.com
Testimonial: " how can i know about that bios if is that the problem how can i update and wich one"
First make
sure there are no disks in any of the drives cd floppy and usb Computer is
booting from a non-bootable source.
Computer
hard disk drive is not properly setup in BIOS.
Corrupt NTLDR and NTDETECT.COM file.
Misconfiguration
with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME
computer that is using FAT32
New hard
disk drive being added. Corrupt boot sector / master boot record.
Seriously
corrupted version of Windows 2000 or Windows XP.
Loose or
Faulty IDE/EIDE hard disk drive cable
Failing to
enable USB keyboard support in the BIOS.
Many times
this error is caused when the computer is attempting to boot from a
non-bootable floppy disk or CDROM First verify that no FLOPPY DISKS or CD is in
the computer, unless you are attempting to boot from a diskette
Test all
power and data leads that attach to your hard drive including IDE,SATA
if ita flat
40 pin ribbon type it will be the first to fail.
The leads
from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust
free connections and are not faulty
Make sure
all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure
connections
Computers need power and data to travel through every
working device and continue its cycle and have an end so any faulty leads will
end up with a computer error
also
When NTLDR is missing from
your operating system it means that there is a problem with your boot loader, a
bootstrap process that begins when you turn on the computer.
A missing NTLDR means that
your computer cannot boot to the operating system.
This issue is only a problem
on computers running Windows XP or previous operating systems as Windows 7 and
Vista don't utilize NTLDR.
Fixing the missing NTLDR is
relatively easy so long as you have your installation disc.
Locate your Windows XP/2000
installation disc and place it in your CD/DVD ROM drive. If you don't have this
disk, then you cannot proceed further.
Restart your computer.
When the computer restarts
press any key on your keyboard when you are prompted, "Press any key to
enter setup."
Most computers are configured
to boot to another device other than a hard drive.
Since the Windows XP/2000
installation disk is bootable, you should see the prompt.
However, if you don't see the
prompt you may need to change your boot priority in your BIOS. To do so, enter
the system BIOS by following the onscreen instructions upon startup.
Then navigate to the Boot
Priority menu and modify another device, such as a CD-ROM to boot prior to the
hard drive.
Then reboot your computer.
After you have pressed any
key, the Windows XP/2000 setup screen will appear.
After loading, press the
"R" key to repair the Windows installation.
The screen will appear black.
The computer requests which
installation you would like to log in. Generally speaking, press "1"
and "Enter."
If you have more than one
hard drive or more than one partition, the procedure may be different.
You must know which hard
drive or partition your Windows operating system is installed in.
You are subsequently prompted
for a password.
If you haven't set up one up,
you can just leave the query blank and press "Enter."
The phrase
"c:\WINDOWS>" and a blinking cursor subsequently appear.
Type "copy d:\i386\ntldr
c:\windows" (without quotes), where "D" is the letter of your
CD/DVD ROM drive (your optical drive may be different, especially if you have
more than one).
Eject the CD from the drive
and type "Exit" (without quotes) to restart your computer.
The NTLDR file will be copied
from the installation disc to your hard drive.
or
If you've started your Windows XP computer and you see an error message
to the effect that the "NTLDR" file is missing or corrupted, you've
probably also noticed that the computer refuses to boot any further.
This is because the NTLDR
file is an integral part of the boot process and needs to be restored before
the boot process can proceed normally.
Insert your Windows XP disc into
your computer.
Restart the computer and
press any key on your keyboard when the message prompting you to do so appears.
Press the "R" key
to open the Recovery Console and then press "1" and "Enter"
in order to select your operating system.
Type in your Administrator
password (if needed) and press "Enter."
c:\" and press "Enter" and then type "copy
d:\i386\ntdetect.com c:\" and press "Enter."
Restart your computer and let
it boot up normally.
Since the NTLDR is freshly
restored, the computer boots up properly.
Hope this helps.
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source.
This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your
Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install
Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
hope this helps
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
hope this helps
