Computers & Internet Logo
Anonymous Posted on Aug 14, 2009
Folder locker I have downloaded two locker. 1 folder hider 2. folder locker.Is it cress one another.
Anonymous
Level 2:
  • Expert 36 Answers
  • Posted on Aug 14, 2009
Anonymous
Expert
Level 2:
Answers
36
Questions
0
Helped
4127
Points
106
Use Lock Folder XP which combines both features in one, instead of having two...
HOW DO I GET A CONFIRMATION PAGE WHEN SENDING A FAX ON MY BIZHUB 20 FAX MACHINE?
Press Menu, 2, 4, 1
Press a or b to choose On, On+Image,
Off or Off+Image.
Press OK.
cress Stop/Exit.
How to unlock locker in folder lock 7.2
Be sure that you read this article and we make no guarantees about the process. Locking software is designed to make data hard to access. http://wiki.answers.com/Q/You_forgot_the_password_of_folder_lock_how_do_you_recover_your_files
The set Code button on my Cress E27 kiln quit working, so I need a wiring diagram to determine if q wire is disconnected or corroded
Could you let me know if its the stock Cress controller or other controller. I have the schematics to a Skutt controller. They operate some what the same. Knowing the voltage and phase of your electrical supply connection would tell me what to send you.
Stevan
[email protected]
2answers
Kindle fire hd lockscreen
Prerequisites:
1. Kindle Fire HD 7", Kindle Fire HD 8.9" or Kindle Fire 2
2. Rooted Kindle: http://forum.xda-developers.com/show....php?t=2069117
3. Google Play: http://forum.xda-developers.com/show....php?t=2069329
Custom Locker Step 1. Using Google Play, search for "No Lock". Download and Install No Lock - You may use this link to verify the software: https://play.google.com/store/apps/d...d.nolock&hl=en
Custom Locker Step 2: DO NOT Open No Lock, it will fail. Next, go to the Kindle, open up ES File Explorer or Root Explorer
Custom Locker Step 3: Be sure to enable Superuser on ES File Explorer. Navigate to /data/app, find org.jaf.androidnolock-1.apk - long press on the APK, select Move or Move To. Next, Move org.jaf.androidnolock-1.apk from /data/app to /system/app.
Custom Locker Step 4: Next find org.jaf.androidnolock-1.apk in /system/app. Long press and Choose Permissions (on Root Explorer) or Properties (on ES File Explorer). Change the Permissions to: Owner: Read Write Group: Read Others: Read - Click OK to apply the Permissions.
Custom Locker Step 5: DO NOT Open No Lock. Pull down the Upper Status Bar, Select More+, Select Sounds & Display and change the Screen Timeout to: Never and then reboot the Kindle.
Custom Locker Step 6: Once the Kindle is back to the desktop, open No Lock which is found in the Kindle Apps, select "Locking disabled".
Custom Locker Step 7: Using Google Play Search for MagicLocker Main which you can find here: https://play.google.com/store/apps/details?id=mobi.lockscreen.magiclocker - Download and Install Magic Locker Main
Custom Locker Step 8: Be sure to enable Superuser on ES File Explorer. Navigate to /data/app, find mobi.lockscreen.magiclocker-1.apk - long press on the APK, select Move or Move To. Next, Move mobi.lockscreen.magiclocker-1.apk from /data/app to /system/app.
Custom Locker Step 9: Next find mobi.lockscreen.magiclocker-1.apk in /system/app. Long press and Choose Permissions (on Root Explorer) or Properties (on ES File Explorer). Change the Permissions to: Owner: Read Write Group: Read Others: Read - Click OK to apply the Permissions.
Custom Locker Step 10: Using Google Play Search for MagicLocker Theme - Download and Install a few Themes that interest you. I use Starry lock screen and Jelly Bean lock screen.
Custom Locker Step 11: Launch MagicLocker Main, click on Next, Next, Next - You will now see a popup, click Next and choose Clear Defaults until it Grays Out, click on the picture of a house (Home Button), you will be asked which Launcher to Use, you choose MagicLocker Main <Select Default>.
Custom Locker Step 12: Launch MagicLocker Main, sometimes you are taken to your regular Launcher App, if this happens repeat Step 11. Select "Lost Robot Music" and click Apply. Next MagicLocker applies the Theme and asks if you would like to Customize it, answer Yes or No depending on your interests. I selected No so we can move on. You can always customize it latter.
Custom Locker Step 13: Next MagicLocker will show you an example of the Theme. Unlock it by pulling down the circle in the Android Picture.
Custom Locker Step 14: Now we need to customize the way MagicLocker reacts when you unlock to the Left which is a Phone Call and when you unlock to the Right which is a SMS Application. Unlock straight down just unlocks the screen.
Custom Locker Step 15: OK, lock the Kindle by depressing the Power Button for 1 brief Second until the screen turns black. Depress the Power Button briefly again, you will see the lock Screen. Unlock to the Right, next you are asked which is your SMS Software, I use Go SMS Pro. Check the Box to "Always use this application". Unlock to the Left, next you are asked which is your Phone Software, I use Google Voice and Groove. Check the Box to "Always use this application".
Custom Locker Step 16: Next, let's install the Themes. Find the name of the Themes you downloaded in Step 8. In this example we picked Starry lock screen and Jelly Bean lock screen. So go into the Apps. Find Starry lock screen, click on Starry lock screen and select "Install this theme". The installer will process and you will be back at the MagicLocker main Theme Menu. Exit MagicLocker, then go to Apps, find Jelly Bean lock screen, click on Starry lock screen and select "Install this theme". The installer will process and you will be back at the MagicLocker main Theme Menu.
Custom Locker Step 17: Now we need to let MagicLocker know what is your Default Launcher, so launch MagicLocker, find Preferred Home Launcher, click on Preferred Home Launcher and select your Launcher, we use Nova Launcher Prime.
Custom Locker Step 18: Let's eliminate the Ads from ever appearing again. Open either ES File Explorer or Root Explorer, navigate to /system/app find the dtcp_apk.ap, long press dtcp_apk.apk select Rename. Rename dtcp_apk.apk to dtcp_apk.old.
Custom Locker Step 19: Reboot the Kindle.
Custom Locker Step 20: Whenever you reboot, the Kindle Fire Framework starts before anything else, so you may see the Kindle lock screen at Reboot IF you do not let everything start. If you can not wait 5 to 10 minutes, unlock it and let all the services start, usually 10 minutes is sufficient. Once you unlock it, you will notice there are no more Ads! After 10 minutes No Lock Service kicks in and disables the Kindle Fire Lock Screen. We have attempted to play with the start-up timing and ended up with Framework missing, so Amazon was smart when they thought out this function. Also, the service that controls the lock screen is part of the same group that displays the Kindle Framework when you unlock it. Finally, if you do wait 10 minutes you will never see the old Kindle Fire Lock Screen!
That is it! Next we will offer you a solution with the stock lock screen but you will need high resolution photos to make it function properly. Be sure to look at our new Backup and Recovery Software for the Kindle Fire Series: http://forum.xda-developers.com/show....php?t=2096888
1helpful
Ii have the trial version of folder protect 1.8.9 that requires a registration key can i get it please
download a locker from the below given link, i recommend this locker because using this you can lock a folder as well as a drive and files.
1helpful
To lock a folder
It becomes mandatory to PROTECT important data files from unwanted use.
Please download the exe from the following path and lock the folders,
http://www.brothersoft.com/locker-download-225109.html
Rate me if this is helpful. Good Luck :)
How can I lock a folder
Folder Lock Opens empty Locker - Should not be empty.
try usin it on another computer,please scan for viruses
Do you have a firing order diagram for a 1982 dodge 150 pick-up truck - 6 cylinder (3.7l)? Thank you Bob Cress email: [email protected]
The firing order should be stamped on the intake manifold. The firing order for V6 is:
1-6-5-4-3-2
1helpful
Password in files
Well if you can save the file but are unsure how to store and keep the file on your pc and have it be safe I would recommend something called Folder Lock. I will provide you a link.
Link: http://www.newsoftwares.net/folderlock/
Summary:
  • On-the-fly 256-bit AES encryption (military standard) for data security.
  • Just as Lockers in physical world, different users can create their own Lockers. A single user can create multiple Lockers with different passwords as well. With Folder Lock, you can choose either to encrypt using 256-bit AES on-the-fly encryption or lock files, folders and drives anywhere on your computer. Each Locker can contain your encrypted files as well as your personal list of locked items.
Grand Canyon Tech
Grand Canyon Tech
