SOURCE: I want to synchronize my
Hi Sir
You Can Use The Itunes App To sync Your Ipad
Now , How to Sync iPad with iTunes 9.1?
There Are 4 Steps .
1. Connect your iPad with the USB cable.
2. Open iTunes and wait for it to recognize your iPad.
3. Depending on your configuration, auto-sync should begin.
4. If not, then manually select whatever features you like to sync your iPad with and press the Sync button.
That’s it! Like I said, it’s the same method like you sync your iPhone or iPod Touch.
SOURCE: Can't delete emails from trash
Hello sir !
Empty Trash Can
In 1982, when Apple created the Apple Lisa user interface, they implemented what they called the Trash Can.
The trash can is essentially purgatory for files a user no longer
wants. Once sent to the trash, the user has the option of restoring the
file back to its original place, or annihilating it completely from the
computer’s hard drive. Unless there is a backup of a user’s system from
before the file was sent to the trash, there is essentially no way of
restoring that file once the trash has been emptied.
This metaphor was carried over to Windows 95
in the form of a Recycle Bin. Perched on the desktop of countless
millions of averages users was this bin which, when empty, looked
empty, and when it contained files, looked full.
There is safety in the Trash Can metaphor. I know that in order to
really delete a file from my system, either on Windows or on Mac OS X,
I really have to work at it. Yes, there are times when files are
accidentally deleted, but for the most part if I realize my mistake
before I empty my Trash, I know the file is safe.
SOURCE: Syncing Outlook 2007 email with iPad
You can sync apple ipad with outlook, there are different ways to do this, I will show you way where you can sync between your Google calendar outlook and your ipad.
Please follow the next steps.
* If you don't have a Google calendar then you can create one here http://www.google.com/calendar/
* Now you'll have to download the Google Calendar Sync, http://www.google.com/support/calendar/bin/answer.py?hl=en&answer=89955
* Follow Google instructions on How to sync Google calendar with outlook, you'll have to insert your email and some other steps that are details at the link above.
* Now it's the ipad turn, from SETTINGS on your iPad select mail then contacts and calendars now select the add account then select Microsoft exchange
* Still with the ipad, from within the Microsoft exchange enter your gmail/email address, leave the domain field empty.
* Enter your password into the screen. Select next from the upper right corner. A message saying “Unable to Verify Certificate” will come up, Click accept.
* A new window, populate the server field with “m.google.com" click next. A new window will ask you to select what will be synchronized from the Exchange server, make your selections and select done.
That's about it now your ipad is synced with outlook through your google calendar.
Hope this will help you with your problem syncing ipad with outlook
SOURCE: I have just got an
You will need to setup a Exchange mail account on your ipad to receive all the mail and calendar items that you see on your Outlook mail and calendar.
Here is how to add an exchange account:
. From the Home Screen, tap Settings
2. Scroll down and tap Mail, Contacts, Calendars
3. Select Add Account > Microsoft Exchange.
4. Now type into the following information:
* Email: your email address
* Username: your-Exchange-User-name
* Password: your-mail-password
* Description: It's Optional
* Server: ****.com
For your username, and server names, you will need to contact your company's IT department for the credentials. But your username is the one your IT dept. gives you for email access and password. exchange server name is the server address to access your mail.
SOURCE: I cannot access old Outlook (2007) emails on my
1)Press settings icon (the one with the cogs)
2) than scroll to Mail, Contacts, Calendar and press it.
3) Find your email account you want to modify and click it
4) find the section on the bottom that says "Mail Days to Sync and press the button
5) Now, you have limited options there, but you can pull email from 1,3 days or 1,2 weeks, 1 month or No Limit. If you click no limit it will pull your entire inbox. So, I might be careful in saying it will drain battery power. And or take room on your ipad away. So, if you have old emails with big attachments, be weary. Plus, depending if you are pulling all this mail over 3G you should take note of your data limits.
Hope that helps.
