SET PROCESS CARTRIDGE ---HOW SOLVE THIS PROBLEM (Seiko LP-1020)
1020 drum laserjet
The OPC drum is contained inside the toner cartridge.. just buy a new toner cartridge! OPC stands for (Organic Photo Conductor) and its part of the toner cartridge.. Buy a new cartridge HP order number is Q2612X or aftermarket
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Feb 04, 2014 | HP LaserJet 1020 Printer
Seiko lp1020 led head
Sir..,Not help for local dealears.,
So. pls ur help sir.,
SEIKO LP-1020 Model Machines
MEP Board (PCP) AFXY U00077354803 (Board arjent)
Account No pls send sr.,
waht price sr.,
Pls help sr.,
Aug 08, 2012 | Seiko Teriostar Lp1020 Printer / Copier /...
I cannot get my Seiko SNA304 chronograph second hand to reset after battery change. Keeps resetting to the 17 minute position, I have tried to use the manual instructions but with no success, Any help...
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
  • THE CROWN
Pull the button on the side of the watch carefully, the crown, out to its most extended position. You will need to unlock the crown if your watch has a locking crown. To unlock, turn the crown counter clockwise. While the crown is pulled out in the setting position, the watch will cease functioning.
  • 12 O'CLOCK POSITION
Turn the crown clockwise to move the hands of the watch past the 12 o'clock position on the dial. The day and date will change to indicate AM setting but will not change for PM setting. It is recommended that you set a Seiko watch in the morning for instant day and date setting; however,this can be done manually.
  • FINISH
To finish setting the time, simply push the crown until it is flush with the side of the watch.
Good luck and thanks for using fixya.
Dec 18, 2010 | Seiko SNA304 Wrist Watch
I have HP Laser Jet 1020 When I print letters
Most cases on that machine it's the transfer roller that does that at 75mm, but could also be drum cartridge or fuser. Use a flashlight and inspect the fuser, shouldn't be toner or image on fuser rollers, If you unplug the machine when the print is in the middle, you can tell if it's before or after the fuser, and after the drum.
Nov 24, 2009 | HP LaserJet 1020 Printer
HP 1020 produces 2 grey lines at edges of page
it is the problem humadity or laser mirror is dirt clean it and then solve your problem
Jul 05, 2009 | HP LaserJet 1020 Printer
Getting vertical line on the right side of the paper
Sounds like a defective toner cartridge. Try replacing it
Apr 23, 2009 | HP LaserJet 1020 Printer
1 inch ink smudge down right side of paper
try going on ur computer that the printer is contected to and have the printer align itself
Mar 17, 2009 | HP LaserJet 1020 Printer
Print quality
Change the PCU cartridge.
Mar 01, 2008 | HP LaserJet 1020 Printer
Hp laser jet 1020
My friend had the same problem. A small sliver of paper was blocking one of the contacts where the cartridge connects with the printer. Removed it and voila!
Nov 01, 2007 | HP LaserJet 1020 Printer
Hp printer 1020
Hello FixYa User,
If you are using thermal paper, Turn the roll upside down (I had the same problem).
If you don't use thermal paper please ring HP on 1 300 888 423 they will tell you whats wrong for free, If the Facsimale is faulty and is under warreanty they will fix it.
Hope this helps!
Sep 15, 2006 | HP 1020 Plain Paper Thermal transfer Fax
24 people viewed this question
k24674
Marvin
Marvin
