I was try to reinstall the driver but not working too..please help me to get a solution about this problem..thks
Hi. i can help you. open up the control panel and then open up where it says hardware, and then printers.
this page shows you how many printers are set up in your computer. Find the one you are trying to reinstall and delete it all together. THEN using your driver, reinstall and you will be back up and running.
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command ,the resetting must makeit work default
