I am trying to transfer music from my Chromebook to my Trio v2 plus but it's confusing?
I have downloaded music on my chromebook and trying to get it on my trio
3 Suggested Answers
SOURCE:
  • 129 Answers
SOURCE: I need help downloading music onto my Mp3 Trio.
Hi..
The first steps you should do is to plug your mp3 to you computer. Once your player will be detected you need easily copy the music files and paste is to your mp3 player.
ICmanServer
Posted on Aug 02, 2009
  • 3698 Answers
SOURCE: I have a trio v2 plus mp3 4GB player where can I
I no longer believe that their are free downloads of music as many people have been sued due to such downloads and had to pay hefty fines. Regular paid downloads are reasonably priced.
Posted on May 12, 2014
Bought a chromebook acer 14 but it will not turn on after fully charged
hi Diane.
How To Fix Your Chromebook If It Won't Turn On More users are reporting that their Chromebooks are not turning on or the screen stays black. For some the problem comes and goes but for others their machine just stays off all the time. If your Chromebook doesn't turn on there is a few different problems that can be the cause.
This article will go through all the possible causes. I've arranged them in order from simplest to fix to most complex so that you can go through them one by one until your Chromebook turns on again.
So just try each fix and stop when your Chromebook turns on! Cheers!
Fix #1: Connect Your Chromebook To Power Let's start with a very simple solution that worked for one of my customers at my computer shop. Simply take your Chromebook, plug it into the wall power outlet, and try to turn it on.
If that doesn't work no worries move onto Fix #2.
Fix #2: Power-Cycle Your Chromebook
  1. Unplug your Chromebook from power.
  2. Remove the battery is that is possible on your model of Chromebook (it isn't on most Chromebooks)
  3. Press and Hold the power button for one whole minute.
Now try to turn on your Chromebook.
Fix #3: EC Reset Your Chromebook Fix #4: Let Your Chromebook Charge For A Few Hours If the Chromebook is very low on charge it may just need to charge. Let it sit plugged in and charging for around four hours. I suggest leaving it plugged in over night.
Try turning it on in the morning.
Fix #5: Disconnect Battery And Power-Cycle (Advanced) Most Chromebook machines have a built in battery that is sealed inside. However most of the batteries are not that difficult to reach if you have a screwdriver and are careful.
Look up a disassembly video for your chromebook model on youtube and watch it to see where the battery is located.
  1. Unplug your chromebook.
  2. Open your chromebook to get to the battery.
  3. Disconnect the battery cable.
  4. Carefully move the chromebook so that you can reach the power button. Press and Hold the power button for one minute.
  5. Re-connect the battery cable. Make sure the connection is secure.
  6. Close up your chromebook. Plug it in.
Try turning it on now.
or try this link out might help you some more.
chromebook acer 14 but it will not turn on Google Search
Dec 03, 2017 | Acer Computers & Internet
How do I prepare a Samsung Chromebook to work with a Blue Intel QX3 microscope when the computer does not have a cd drive?
First please realize that a Chromebook is not the same as a Windows laptop/desktop and your microscope will most likely never work on the Chromebook. This is because we are talking about two different operating systems, with the Chromebook having a very slim Google operating system, called Chrome OS, designed for mainly web browsing and using web based tools such as Google Drive.
You can try to find a driver for the microscope that you can download from the web straight onto the Chromebook. BUT remember, the driver HAS to be for the Chromebook. A Windows driver will not work!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/thomas_e8f475a8655f7b4a
Feb 27, 2016 | Samsung XE500C21-A04US 12.1" Chrome OS...
Why can't I install the operating system?
DF]HP Pavilion 14 Chromebook - Hewlett Packard
www8.hp.com/h20195/v2/GetPDF.../c04142220.pdf
Hewlett?PackardAug 15, 2013 - processor, chipset, BIOS, operating system, device drivers, and applications ... HP Pavilion 14 Chromebook (16 GB mSATA Solid State Drive).
Sep 30, 2015 | HP Pavilion Chromebook 14
How do i tranfer my photos from sumsung chromebook to usb
I'm not familiar with the Chromebook OS but I'm assuming that you should be able to copy and paste them if it doesn't have a programme or app you can do it from.
1. Insert your usb device (your chromebook should recognize this as an additional drive).
2. Open the folder with the photos you want to transfer select *copy
then open the window for the usb drive and select *paste (*usually commands found when you right click on a mouse).
Feb 25, 2015 | Samsung Chromebook Series 3
What is the simplest way to transfer pictures and videos from my I-Phone 4S to my Chromebook ??
Join Google drive
Install Google drive on iPhone
Upload/download as required but make sure your using wifi
Jan 03, 2015 | Cell Phones
How to download from flash drive onto a chromebook the easiest way possible
http://kb.sandisk.com/app/answers/detail/a_id/15839/~/transferring-files-from-memory-card-or-flash-drive-using-chromebook
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Nov 12, 2014 | Samsung Chromebook Series 3 XE303C12
Lcpdfr chromebook
only if your chromebook supports GTA IV
Aug 05, 2014 | Samsung XE500C21-A04US 12.1" Chrome OS...
Need pairing code for my chromebook to be one of my network devices
The defualt paring pin might be in the user manual, also the defualt pairing pin might be 0000 or 1234
Apr 01, 2014 | Acer Computers & Internet
I have a chromebook which does not have disc holder how do i download information from the disc to chromebook
Drop the files from a computer with a optic drive into a Google Drive and open it on the Chromebook
Nov 13, 2013 | Canon Computers & Internet
 Grubhead
Grubhead
Marvin
Marvin
