SOURCE: No Picture, sound is all static
Make sure the ant. input switch didnt change and check the ant. connections If that dosent work sounds like a defective tuner.
SOURCE: LARGE BLACK RECTANGLE BAR BLOCKING TV SHOWS -- WILL NOT GO AWAY
It sounds like the closed captioning background.
Press Menu on the remote
Press Up or Down, Ch + or C- to get to Closed Caption
Press right side button or Vol+ and Mode will be highlighted
Press right button or Vol+ until it says Off on the right hand side of the Menu
Press exit and that should do it.
Hope this helps.
SOURCE: Black box showing up in center of tv
your closed caption feature is turn on and in the text mode. either turn off the closed captions or change it from text to cc1
SOURCE: Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
SOURCE: Toshiba 32AF45 Black Rectangle Issue
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
