Frigidaire model MEF352BGWB kitchen range. Preheat beaper beaps randomly even though oven is still up to temp. Top oven element turned on even though the dial was turned off. Locked and started self cleaning all on it's own. We turned of the circuit breaker for fear this appliance has a mind of it's own.
SOURCE: Frigidaire gas range broiler element does not light.
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
SOURCE: Frigidaire range model #FEFLFSA, is the top element
When you say Top Element, I assume you mean the TOP OVEN ELEMENT, correct? You have bake, and broil? Bake is usually on the bottom, and broil is the top. In order to have the oven operate correctly, the top and bottom elements may come on at start, in order to do as you just said, "Preheat the oven". This will insure an even distribution of the heat in the oven box and result in better cooking expierences. I would not be alarmed or concerned if the top element came on for a short period to pre-heat in preparation for cooking. This is normal. If the top element stayed on, and did not shut off on bake after the pre-heat period, then I would say you have a control board problem. However, if it comes on and then goes out, except when you are broiling, then I would say that this is normal for your stove, and the pre-heat mode of operations. Your owners manual should advise you of this very process in the guide section to how to use the oven. I hope this helps and that all your cakes, pies, souffle's and the like are......delicious. I'm sure they are. I hope this helps and eases your concerns. Kindest regards, Slats.
SOURCE: Frigidaire Model ES200 White Electric Range f1
F-1 USUALLY MEENS THE MAIN PCB OR CLOCK ***. I WOULD RECOMEND REMOVING THE POWER AND PULLING IT AWAY FROM THE WALL .TAKE THE BACK PANNEL OFF AND LOOK FOR A BURN MARK. THAT SHOULD SHOW WHAT BLEW.
GOOD LUCK!
ERIC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
What is the complete model number of your unit?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
A few questions first. How old is your oven? What is the entire model # that is on the sticker on the oven. Model # should be somewhere behind the bottom drawer.
