I have a samsung hl-r6178w, it suddenly turned off & the 3 lights in the front started blinking & it would not turn back on. i replaced the lamp now & still nothing, what can i do?
SOURCE: i have a samsung hl-r6178w, it suddenly turned off
In regards to your issue, I got a question for you: when your tv turns on or tries to turn on, do you or can you hear a humming, buzzing or rapid click noise coming out of the tv? if you say yes this could be an issue with the ballast and most likely needs to be replaced as soon as possible the definition of a ballast and how it works is this: A ballast is an electrical component used with a fluorescent bulb (or mercury vapor lamp or arc lamp) to conduct electricity at each end of the tube. It supplies the initial electricity to the bulb that creates light, and then it regulates the amount of electricity flowing through the bulb so that it emits the right amount of light
You can go to DM the have this parts and you can get a good price,http://www.discount-merchant.com/?click=52978
please keep us posted
good luck
