Hello Jason, You need to download these 3 links that should help you fix the problem.
Best of luck,
JP
https://youtu.be/5aOfdzXczSM
https://youtu.be/iUBSAm78Q9I
https://www.manualslib.com/manual/409048/Frigidaire-Fafs4073na.html#manual
SOURCE: Pause Error - Frigidaire Affinity LTF6000ES0
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
SOURCE: Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
SOURCE: frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
SOURCE: my Frigidaire affinity washer doesn't
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
SOURCE: fabric softener will not drain
Try cleaning out ..this should cure . the other thing that can cause this is a faulty solonoid valve as some machines have a seperate valve for this action....
Hello Larry Occhipinti, thank you for your post!
If you are pushing the necessary buttons on your Frigidaire washer to perform a system clean and they are not working, it could be a possible issue within the control panel. I would recommend a reset on your appliance which can be done by disconnecting power from your appliance for roughly ten minutes. If that does not correct the issue, you can run a hot water wash cycle with a cup of bleach inside the tub to clean your appliance out as well. I hope this is helpful. -Matt
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Here is a tip about how to clean your washer
How to have a Clean Washer
heatman101
