Question about Trilogy Locks & Locksmithing
I want to program the trilogy pdl 3000 to make the pass time unlimited when I use a proxy card
How do I program the Trilogy DK3000 for the upcoming time change?
Alarm Lock is the manufacturer of your lock:
http://www.alarmlock.com/tech_library_instruction_manuals.asp
You will find the specific steps on page 21 of the online programming manual. Here's the link to it:
http://napcosecurity.com/download/DK3000_WI1119E.04_PROG.pdf
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
good luck- an please provide feedback if this helps!
Nov 03, 2011 | Trilogy Alarm Lock T2 TRILOGY® Digital...
Some websites are block by proxy. How can I by pass proxy?
Setup Vpn for windows 7 setting VPN connection to bypass proxy and open any blocked website freely and anonymously with unlimited bandwidth and high speed connection
Jul 26, 2011 | Computers & Internet
Where can I find instructions for installing a T2 Trilogy Unit
Go to this page for Alarm lock, the manufacturer:
where you will find it listed under the heading
Trilogy DL installation manuals
http://napcosecurity.com/download/DL2700_WI835_INST.pdf
and the programming instructions under
Trilogy DL programming manuals
http://napcosecurity.com/download/DL2700_OI209A.37_PROG.pdf
These digital manuals are .PDF files. If they don't open for you, it is because you need to install Adobe Reader on your computer first. So here's the link to download the installation file for Adobe:
A note of caution regarding the installation: a printout of a template will probably be scaled down by your printer and therefore not be true dimension.
Hope this helps. Good luck with your installation!
Jul 22, 2011 | Trilogy Alarm Lock T2 TRILOGY Digital...
Forgot how to set my user codes in my older Trilogy lock
Here is a link to a PDF file for the Trilogy 2 lock programming:
http://www.glenskey.com/download/DL2700_OI209_PROG.pdf
I hope this solves your problem--Good luck!
Feb 11, 2011 | Trilogy Alarm Lock T2 TRILOGY® Digital...
I've lost the programming code for my trilogy lock.How to I set it backt to default?
unplug the battery, then press any key on the keypad within 5 seconds. You will hear a dying beep. Plug the battery in and you are set.
Mar 12, 2010 | Trilogy Alarm Lock T2 TRILOGY® Digital...
How to read data from zebex pdl-20
Use WinTaskGen to download data from the device. If you need the program I can send it to you
Jan 06, 2010 | Zebex PDL-20 Portable Terminal
Trilogy dl 2700 serries digital lock program managers code
First you need to know if you have a standard 2700 or the new enhanced version, it makes a big difference. Press any 2 buttons then star, if you get no response it is a standard version, if it beeps several times it is the new version. If it is the standard version, disconnect the battery and press any button. Now you are at factory default. Reprogram the master code, remember the master code and the operating code must b e the same length. 12345 A 1 A new master code A new master code. The master code is the only code that needs to be entered twice during it's programming. To set a manager code press; master code A2A new manager code, to set a new user code; enter master code or manager code A11A new user code. The programming must be done during the lock's unlock window so write down the procedure you intend to use to make things go quicker, if you need more time you can change the unlock window, it is probably set at the factoy 5 seconds. Press master code A45A4, this will give you a 20 second window to program the lock, when you are finished change the lock back to 5 seconds, press; master code A45A1, keep the open window short to conserve batteries.
Feb 18, 2009 | Trilogy Alarm Lock T2 TRILOGY® Digital...
Locks & Locksmithing Logo
27 people viewed this question
Top Trilogy Locks & Locksmithing Experts
john h
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Trilogy Lock and Locksmithing Expert? Answer questions, earn points and help others
