Televison & Video Logo
Posted on Aug 13, 2009
I have no color on my samsung hln5065wx/xaa DLP tv. Is it my color wheel or bulb ?
Farmeradg
Level 1:
  • Contributor 32 Answers
  • Posted on Aug 13, 2009
Farmeradg
Contributor
Level 1:
Answers
32
Questions
0
Helped
7001
Points
50
If it is just no color but you still have a picture it should be your digital board. This is the board that mounts behind the light engine and should be encased in a shilver colored metal sheild
I have a 50" Samsung Tv. Model Number:
Some of these (many) had issues with a color wheel---high pitched or fan light sound that declines when set turned off----Got this?
Samsung DLP HLN5065WX/XAA
that's from a thermal switch, to keep the innards cool, post use. Seems to me that you might just check to see that all vents are open and clear of debris, for starters.
We have a Samsung #HLN5065WX/XAA that has started making a very strange noise and flashing "Check fan no. 2". The colors are also off. What can I do to fix this?
The tv is making loud noises like humming or motor noises and tv have strange colors flashes or black and white backgrond flashes.The tv Colors wheel it is dying and not spinning the right speed of it RMP speed any more.The tv colors wheel must have be replaced to solved this problems.Have no mechanicals skills hire a tv tech. to change the tv colors wheel because u have to take out alot of mechanical parts out before u can come to the tv colors wheel itself to replace it.
2helpful
2helpful
Samsung Model HLR4667WAX/XAA is making a buzzing sound
It is likely the color wheel motor making noise
Check this link
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
If it helps be sure to vote/rate me Thanks
Part number for color wheel
That model is a plasma TV? Plasma TV's don;t use color wheels. Only the DLP sets do.
1helpful
3answers
TV won't stay on
Hello Fonzell!
Regarding the tv turning, my question is, do you hear a clicking sound? if so, it's most probable tio be your ballast, that might not have enough voltage to keep on with your lamp, and that's why it shuts off.
You could try replacing it and seeing if it resolves your issue, I believe they're running around 70 dlls..
have a great one ! :)
Samsung model HLN5065WX / XAA
You need a new color wheel. Go to www.samsung.com and do some searches. I had to have someone come out and replace mine.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
