It worked fine with Spectrum box connected, but i cut the cord and have gone to indoor antenna - now i can't get the fire tv recognized.
Hola, Wanda indica la marca, el modelo y el tipo de equipo que est? comentando para encontrar la mejor soluci?n.
Espero su respuesta.
Saludos Franco Dosil
Hola Wanda indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
SOURCE: Cannot get a connection with HDMI input
When the tv won't scroll to the HDMI inputs, it means that the tv does not detect a signal on those inputs. This either means the tv has an issue and can't receive an HDMI signal(very unlikely) or there is no signal being sent from the source(converter box) The first thing I would do is unplug all output connections from the box except for the HDMI output and see if this gets rid of your problem. If not, I would be more inclined to think you have a problem with your converter box than with your TV. You could also try using the HDMI ouput of a DVD player if you have one.
SOURCE: Toshiba TV fails to recognize HDMI input
If the tv does all those symptoms but after some seconds the tv works and stays doing the job. THen the tv has a slow microprocessor to recognice the different resolutions or video inputs.
But if the tv cannot do anything and stay aout of signal forever. send the tv to the waranty. (no waranty? you have to use the component input instead to have digital signal reproduced
SOURCE: JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
SOURCE: LG HT502 wont recognize hdmi cable. it says hdmi
go into the video setup menu, and select HDMI set up and select "ON" that should do it
SOURCE: Sony Bravia does not recognize my Dell Inspiron 1525
I have the 1525 and you have to do extra steps each time you want the HDMI to be recognized by the Bravia - too bad it is not automatic as it is with some. Anyway what you have to do is have the HDMI cable connected from laptop to TV then go to your desktop - right click on an open area (away from icons), a menu will appear, let the cursor hover over Graphics Options - you'll then see Output To...then you'll see Intel Dual Display Clone...hover over that and you'll then see Notebook + Digital Television...left click on that and you should see your desktop on the TV in a few seconds. If it does not work the first time...get your movie or whatever you want to show up and ready and go thru these steps again...stupidly complicated aye? when it should automatically detect and show...are other TVs like this?
