Question about Remington Optics
Correct Load 22-250 Remington AI with 55gr bullets.It is a Sako 26 inch bull barrel.The charge of 42g with MRP is not giving enough velocity .Primer is cci 200 standard.What powder should i use.
2 Suggested Answers
SOURCE:
  • 2418 Answers
SOURCE: I am using Hodgdon 4895 smokeless powder and a 200
Oh me, that was fun I have not got out my books for so long.  Ok this is from Hornady Handbook Starting load for the 200 gr RN Bullet using H4895 is 34.3 gr using a Remington case with a Federal 210 Primer Max C.O.L. (Cart.over all length) is 1.920. Max load for this is 39.0 gr. Work up, look for case bulging & primer flowing. Be carefull.
Posted on Sep 24, 2009
Hornady 25 cal 117 gr r n 25-06 loads
Oct 07, 2018 | Firearms
Do you have bullet drop for the 450 Bushmaster
From a friend - All bullet drop depends on the bullet weight, load and barrel. So, a 450 bushmaster with 20" barrel on it and done some work with it the past few days. After some trouble dialing in the scope multiple times I finally got it on at 100 yards. With a 100 yard zero (around 1.5" groups which isn't too good but I believe it is due to my scope which is going to get replaced shortly) we shot it out at 300 yards to see what it would do. We calculated the drop to be approximately 30" with the 100 yard zero. First few shots we were not on paper so we raised hold point up a few inches and we had our first mark. After 2 more shots we had a group to measure from. Back at the house we measured the 3 shot group at 300 yards to be 7.5 inches. (again I am confident this can perform better with a better optic) and 37.5" low. With a 2000 fps velocity and 250 gr bullet from Hornady, it puts the ballistics at
100 yrds- 0" drop, 2030 ft lbs energy, 1912 fps
200 yrds- 9.5" drop, 1067 ft lbs energy, 1386 fps
300 yrds- 37.5" drop, 760 ft obs energy, 1170 fps
Oct 03, 2017 | The Optics
Need a bullet drop chart for a 1917 eddystone 30 06 with a 26 in barrel using hornady 150gr round.
Results are really only needed for caliber, load (in grains) and round in weight and style.
    [PDF]Standard Ballistics Chart - Hornady
    www.hornady.com/assets/files/ballistics/2015-Standard-Ballistics.pdf Velocity(fps). Energy(ft/lb). Trajectory Tables(inches). CARTRIDGE. BULLET. ITEM #. MUZ 100 yd 200 ..... Bullet. LRN . . . . . Lead Round Nose ..... 0. -6.4 -18.8 -38.3. AW 30-06 Springfield. 150 gr. InterLock® SP. 8108. 2910. 2637. 2381. 2139.
    [PDF]HMC 07704 Ballistics Charts as PDFs - Hornady
    www.hornady.com/images/ballistics/ballistics_charts.pdf Velocity (fps) / Energy (ft/lb). Trajectory Tables. CARTRIDGE. BULLET. ITEM # ..... LM 30-06 Sprg. 150 gr. SST LM InterLock. 8519. 3100/3200. 2867/2736. 2645/ ...
    [PDF]Hornady ballistics charts
    www.hornady.com/assets/files/ballistics/ballistics_charts.pdf Trajectory Tables. CARTRIDGE. BULLET. ITEM # HITS #. MUZZLE. 100 yds. 200 yds ..... C 30-06 Sprg. 150 gr. SST InterLock. 8109. 911. 2910/2820. 2686/2403.
    [PDF]Trajectory Tables - Hornady
    www.hornady.com/assets/files/ballistics/2013-Standard-Ballistics.pdf Velocity(fps). Energy(ft/lb). Trajectory Tables(inches). CARTRIDGE. BULLET ...... 30-06 Sprg. 150 gr. InterLock SP. 8110. 2910. 2637. 2381. 2139. 1911. 1700.
    30-06 Ballistics Chart & Coefficient GunData.org
    gundata.org/blog/post/30-06-ballistics-chart/ Jul 11, 2012 - ... 1000 yard 30-06 ballistic charting of a Remington 30-06 Springfield 165 Grain AccuTip Boat Tail with a BC (Ballistic Coeficient) of .447 that was created using our free ballistic trajectory calculator. ... 150, -1.1424, 2499, 2288, 0.17 ... 600 Round Glock Magazine · 10mm vs 40 Summary and Ballistics · How ...
    30-06 Springfield / Hunting & Ballistics:
    www.gunnersden.com/index.htm.30-06springfield-ballistics-hunting.html External ballistics pertains to bullet velocity, energy and trajectory down-range. ... Below are several hunting ballistics sight-in charts for 30-06 Springfield ammunition that ... Ammunition manufacturer: Hornady. ... Bullet weight: 150 Grains.
    30-06 Springfield:
    www.gunnersden.com/index.htm.30-06springfield.html 30-06 Springfield Cartridge, Rifles, Reloading And Ballistics Information. ... Ammunition: Hornady 150 grain SST bullet. Bullet diameter: .308 inch. Bullet
Jan 19, 2016 | Optics
I have a bushnell elite 4200 mildot you can get it 0 perfect shoot 3 to7 times it will move 1 to 2 inches left or right up and down stay perfect. gun has a fixed front bypod and fixed rear adj. rest...
Not sure what your asking, but I will try to explain what I think is going on. If you fire the gun cold (one or two shots) and you are on target or zeroed in. Then the more you shot, the point of impact wanders off center or gets worse. This can be caused by the receiver getting hot (warm) from firing, and tweaking the scope in the rings enough to move it. Another reason can be the bullets you are using Then also through a hot (warm) barrel. Bullets stringing or shot placement going up / down can be attributed to the hot (warm) barrel. As the barrel gets warm the diameter increases and gas from the powder will escape around the bullet in the bore and cause flame cutting. Flame cutting can/ will cause a decrease in muzzle velocity, which will string the bullets in a vertical line out at target range. Horizontal bullet placement is caused by sight errors (scope moving) or movement of the gun in the shooters rest, called flinching, or "pulling" as the shooter expects the gun to go off. One way to find out if this is what is happing, is to have a friend load the gun or not load the gun (single rounds) and hand it to you to fire. if your friend does not load it and you flinch thinking shes about to go off you have to work on that aspect of your control. Once you have that control issue out of the way you will see a huge improvement in your shot placement.Hope this helps Fix Ya up.
Apr 05, 2011 | Bushnell Elite 4200 6-24x40 Riflescope...
HAVE A PRONGHORN TASCO MOUNTED ON SAVAGE 22 BOLT. SIGHTS IN OKAY AT 10 YARDS AND THEN IS HIGH AT 25. IS THERE AN ADJUSTMENT INTERNALLY IN SCOPE TO FIX THIS?
No, this is not a scope issue. The scope is raised above the centerline of the barrel, thus at 10 yards, the barrell is actually slightly raised in relation to the centerline of the scope in order to hit your point of aim. Since the front of the barrel is slightly inclined, at 25 yards the bullet is still rising in relation to the scope alignment. Backing up to 50 yards you will begin to see the bullet start to drop back down, at 100 yards it may drop as much as 8-10 inches, and at 200 yards, it may drop as much as 52 inches. This is assuming that you are shooting a standard velocity .22 long rifle cartridge (1050 feet per second or so).
Sep 10, 2010 | Tasco Pronghorn 3-9x50mm 30/30 Riflescope...
Remington Powder Actuated Tool Model 476D. Ram set. Drives concrete nails with a 22 size charge. Barrel seems to be clogged. Looking for a manual that shows the interior cross section. There is not a...
the tool got stuck, after a shot, it stayed up and I cannot release it to put a bullet and a nail for the next shot, what can I do, I tried to undo the nut in the top of the tool with no success.
Mar 06, 2010 | Remington Powder Actuated To Power Load...
I am using Hodgdon 4895 smokeless powder and a 200 grain soft nosed bullet to reload for a 35 cal marlin rifle. What powder charge should I start with to safely reload these bullets.
Aug 30, 2009 | Optics
Rifle is shooting "strings" First round hits where I want it to and then I end up with a 5 shot group that is 6 inches long and one inch wide moving upwards from original hit at a 45 degree angle from...
The reason your shots are stringing is because the barrel is touching the stock probably at the end of the forearm. As the barrel heats up, the problem gets worse. Try sanding out the barrel channel and free-floating the barrel all the way to the recoil lug. Next, torque the action in the stock the recommended amount with an inch pound torque wrench. I torque my Remington 700 at 45 inch pounds for the front screw and 35 inch pounds for the rear screw. If you have a plastic trigger guard, 35 inch pounds will be too much for the light plastic trigger guard.
Aug 11, 2009 | Tasco Optics
Optics Logo
18 people viewed this question
Top Remington Optics Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
vince
Are you a Remington Optic Expert? Answer questions, earn points and help others
