My dell laptop boots up normally with the back light on but with a pinkish hue then when it is fully booted the screen goes black with icons barely visible, I have changed the lcd inverter and the problem still occurs
Test to see if an external monitor works. If it does, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
In either case, a technician in your area should be able to help. Evaluate to see if the repair is cost-effective.
Since an external monitor works, it is the display's backlight or inverter board.
Boot the machine into safe mode. Right click on My Computer (XP) Computer (Vista) and select manage from the sub menu. When the window pops up select Device Manager. A device list will populate. When it has look down the list for Display Adapters. Click on the + icon next to Display Adapters to it expands. Right click on the display adapter and select uninstall.
Restart the computer and let it boot in normal mode. If it boots in normal mode let it detect the Display and install the drivers for it. I would be a good idea to update the display drivers via the Dell support website.
If it still won't display in normal mode please post back.
You can check the brightness with AC in the BIOS and match it with running in battery or else, when you plug the ac adapter, the lcd goes dim, press and hold the FN buttong and tap the up arrow then reboot and try to see if it will still do it. But still the best way to do it is going to the BIOS by pressing F2 at the Dell logo startup.
