Question about Nokia Cell Phones
I have a Nokia Expressmusic phone which i use on holidays to listen to music only. There is a old SIM card in which is not used anymore and has been in the phone for years. This year I used the phone for two days but now when switching on I cannot get past the time and date screen - all buttons on it are totally none responsive?
SOURCE:
Rayborn
  • 92 Answers
SOURCE: nokia e65 will not accept any sim card after i unlocked the phone
I would try the unlock again, it sounds like the unlock was unsuccessful otherwise it would have allowed you to use the other sim cards.
Posted on Jan 27, 2009
  • 272 Answers
SOURCE: Phone not accepting a new SIM card
I think you have activated this sim only lock. This should be found under security menu. Try unlocking i first. If none works, you may consider flashing the phone if you need the phone working.
Posted on May 27, 2009
SOURCE: Nokia e 61i white screen
My Nokia E61i sometimes starts up with the welcome screen and works normal for a while.
Then sometimes the screen will flash on start up or continues to flash
with spotted colors and not come on. Could this be a software problem?
Thank you Jason
Posted on Nov 29, 2010
supernova278
  • 1932 Answers
SOURCE: my nokia 2700 classic phone
If your phone freezes, hangs up unexpectedly, vibrates continuously ,touch screen wont respond or in other similar ways doesn't perform as it should, this can often be solved by performing a software update. Software may perform incorrectly for many reasons without there being a fault in the phone. Some problems may be fixed by re-updating your current software, while others may require installing a new software version.
To keep your phone performing at its best, it's a good idea to perform a software update regularly. You might not always notice what an update has done, but it can prevent future problems.
To update or reinstall the software please go to nearest authorized service centre of your mobile make and they will update or reinstall the software as required.
Note: Reinstalling the software will delete all the content in your phone like contacts, calendar entry etc.
Thank You
Posted on Feb 07, 2011
  • 148 Answers
SOURCE: I have a nokia 5310. When I insert my Airtel or
hi
you are installed a security code when you are using your old sim cards
so if you wont to install a new sim card you have to know your security code
other wise
1) insert your old sim card
2) switch on the phone and back up all data
3) Connect your phone to pc using Nokia PC Suite and Data cable
4) make sure about your data
5) Download the Nokia Software updater
6) Update your phone software or reinstall if you have already latest software
if any doubt replay me
Link for nokia Software updater
http://www.nokia.co.in/support/product_support/phone-software-update
Posted on May 27, 2011
I am trying to use the sim card and my current payment plans with boost on my old at&t phone that i got unlocked, but i need to know how to make that work..
the sim card is still tied to the previous service provider
get a new sim card from your new service provider
keep the plastic card that the sim card is attached to as there is the PUK code that you will need to open the phone stamped on that plastic card
Dec 10, 2015 | Nokia Lumia 635 Windows Blue Boost Mobile
NOKIA EXPRESSMUSIC 5800 SIM NOT VALID
Remove SIM and check on another phone, if this does not work replace card. If not clean the connections and try Also if is possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Jul 16, 2011 | Nokia 5800 XpressMusic Smartphone
Please send me the PUK no of my nokia 5800 expressmusic phone my IEMI no is 354182/02/284868/1
the PUK number comes with the sim card you are using. all you need to do is to check the pack of the sim and go through all the information there and you would find the PUK code. it is normally determined by the network and not the phone make or model
Nov 09, 2010 | Nokia 5800 XpressMusic Smartphone
Security code for nokia 5310
just go to your phone settings and select security option and then there will be key pad lock option and like sim lock option just give your code and imply it you can use both the ways but if you want strict then sim lock option is better
Jun 05, 2010 | Nokia 5310 Cellular Phone
I have a nokia 5530 expressmusic how do i unlock it to recieve all networks
Use this site to unlock your mobile...
1 - Switch on your Nokia 5530 Xpress music without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5530 Xpress music.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5530 Xpress music would then display the message "SIM Restriction Off" and will be unlocked!
If you need unlock code...You can get the unlock code here theunlockarena.com
Apr 25, 2010 | Nokia 5530 XpressMusic Smartphone
I've got a Nokia 2630 nice looking mobil phone. I
Hello :
to unlock your phone , you need to restore factory settings .
Here is the way :
Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to switch on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
good luck
rate if useful please !
Feb 08, 2010 | Nokia Cell Phones
Can i save pictures music to my sim card, as i have a new phone but my music is still on my old phone
THe sim does not have enough space to save pictures. only those contacts.
Jun 24, 2009 | Nokia 6230
5310 Nokia expressmusic phone unlock code???
The e-mail solution posted by Nokia below to unlock the media licence keys after firmware update worked and is thus (Note all your phone music will be wiped so will need to upload again from your PC):
1. Connect your phone to Nokia PC Suite in "PC Suite" mode. Launch PC Suite.
2. Use PC Suite Content Copier to back up the contents of the memory card onto the PC.
3. Disconnect the phone and format the memory card:
Menu > Gallery > (the memory card folder) > Options > Format memory card > Yes.
4. Re-connect your phone to PC Suite and restore the backed up data to the memory card.
Feb 12, 2009 | Nokia 5310 Cellular Phone
Cell Phones Logo
21 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
ASHRAF CA
ASHRAF CA
