Freezers Logo
Posted on Aug 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My ice maker has stopped working
The ice tray is not taking in the water so there us no ice
John Tripp
Level 3:
  • Master 4,656 Answers
  • Posted on Aug 14, 2009
John Tripp
Master
Level 3:
Answers
4656
Questions
Helped
1678117
Points
14883
The problem is most likely the water control valve on rear of refrigerator.There are two sides on what is called a dual water control valve. If I had your model number I could tell you the part number. The second possibility is the thermostat inside the ice maker is defective. The way to test is to fill ice maker with tap water let freeze and if it dumps and does not refill then the water valve must be replaced. Let me know and please rate my solution, Thanks, Sea Breeze
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
I have a GE Profile fridge PSS25MGNAWW with an ice maker that is not working properly. The ice maker doesnt fill with water. If I turn the ice maker off then back on it will squirt water in for about...
HI this is just a test the icemaker runs when you first turn it on, its not suppose to fill up the tray, it will fill it when the icemaker reaches the correct temperature, if its not cold enough in the freezer it wont kick on, if its been sitting for several hours and still wont fill or make ice, you need a new icemaker. The new icemaker part # is WR30X10093
Sean
Mar 30, 2011 • GE Freezers
1helpful
Jen Aire Fridge ice maker fingers are below the
This one you have to take out the ice maker and run hot water from the kitchen sink into the tray to get the ice out. need model number if you want detail explaination how to. or just use a hair dryer that will work to!!! if fingers dont rotate after defrost ice then the gears are stripped, replace ice maker
Ice maker not working on Kenmore Model # 106.54563300 Water comes through water dispenser fine Water came pouring out through ice dispenser door so I flipped bar up to turn it off Removed front box held in...
First the arm has to be in the down position. It sounds like you said theres water in the ice maker. If thats the case then it should have frozed. The ice cannot drop unless the ice maker heater comes on. Then the ice maker scoops the ice and drops into the resoviour thingy. If you have ice in the ice maker tray but no ice in the bucket then the ice maker is defective.
The fridge is no longer making ice
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
OR
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 19, 2009 • Freezers
Ice maker not getting water
Probably the dual water valve (that opens when the ice maker needs water ) is leaking and the filling tube gets clogh with ice , or the valve doesn't work ,in both cases it has to be replace.
1helpful
Our model 532 keeps over filling the ice maker causing a build up on the back and down all of the drawer. We can turn it off and thaw the entire box and the water keeps filling the tray even though the ice...
The fill valve for the ice maker could be stuck partially open and dripping into the ice maker. If this is the case shut off the water line to the ice maker and if the water stops you will need to replace the ice maker fill vavle
Ice maker is making ice cubes AND pouring water
the apparatus that distributes the water into the tray had been knocked out of balance when taking the tray out. We pulled the ice maker and replaced the apparatus back in it's proper location .
Aug 07, 2009 • Freezers
2helpful
2answers
Jen aire ice maker not working
change filter and defrost water lines if frozen
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
