Question about Sony Office Equipment & Supplies
How can I release the paper jam in SONY UP-D897
2 Suggested Answers
SOURCE:
SOURCE: Paper jammed at exit rollers of Canon D860. Paper
If you remove the plastic covers on that side of the printer, you will see a small screw holding a bar against the rollers. Set the printer on end so you can remove this screw with out dropping it into the printer, and then the rollers will be loose enough that you can get the paper out.
Posted on May 25, 2010
I NEED SONY UP-897MD DRIVER
look up driver downloads there are a few that may help
Dec 10, 2012 | Sony UP-D897 Printer
We need Sony UP-897MD Printer service manual
Repair Parts : Customer Service: ordering, order tracking, returns Email: ProParts@am.sony.com Email: ProPartsResearch@am.sony.com Phone: 800-538-7550, 9:00 a.m. - 7:00 p.m. ET, Monday - Friday.
May 30, 2011 | Sony UP-D897 Printer
Why does printer gives dark print?
its because of jamming up of the cartage rather u can check your printinng setting.
Jan 14, 2011 | Sony UP-D897 Printer
I need sony up-d897 driver for windows7
try going to www.sony.com for driver support and updates
Jul 28, 2010 | Sony UP-D897 Printer
I have a paper jammed in the printer and I cannot get it out.
Normally the paaper gets jammed into the rollers and the drives and could be easily released if you can use the copy keys to forward the drive.There could be also paper lodged in the feed rollers or the inner roller could have jammed into. If so you will have to release the holding screws of the roller and remove off the paper. If the dispaly is showing paper jammed there is also the possibility that the paper detect in optocoupler sensor is faulty. If so check and replace this which is found at the paper feed on. Once the display shows a release the printer should work . Hope you try out. Good day
Jul 05, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Paper jam message...but no paper is jamming system
is a small finger plastic, stucked on the paper path, release-it and problem solved. (Is very fragile, so use a small tool to release)
Dec 29, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Jammed paper
Removed the new paper from feed slot, pressed the on button which allowed the `grabber` to release the jammed paper slightly and then was able to [with the aid of long tweezers] remove the jammed paper through the feed slot.
Regards
Geoff
Feb 04, 2009 | Epson Stylus CX6400 All-In-One InkJet...
19 people viewed this question
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
jasbo
jasbo
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
