There is a switch on the right-hand side of the machine labelled 'VOX'. Set this switch to the 'OFF' position and you should be good to go.
'VOX' is voice-activated recording. It's designed to record only when someone is talking, and to pause when nothing is being said. In theory it's a great feature, but it never really works as good as you'd like. It'll usually miss the first few words you say, or it'll cut in & out while you're talking.
You can also set the 'VOX' sensitivity by adjusting the 'Tone/VOX' slider on the front of the machine.
Hope this helps...
Testimonial: "You solved my problem!"
