SOURCE: Using TV card on PC video perfect no audio
SOme PVR cards need a small cable from PVR card to the Sound card input to play sound via the sound card.
SOURCE: C02 error
No setting is required. If you can, remove the Imprinter cover, clean the sensor and put the cover back. Hope the sensor has not failed.
S. Mohan.
SOURCE: significant volume decrease when using Comcast cable box
you might have to talk to comcast about that most signals are low for reasons of conservation of bandwidth, they may also be sending 5.1 which tends to be lower volume and adds surround in.
mono is always loud, and that is what you get with 75 ohm coaxial cable (single screw in ).
hope this helps.
SOURCE: Black and White Video - Wii Component cable
put yellow in video red and white in audio and change source to av
SOURCE: black and white dstv
look on the TV menu for (system) in south africa we use PAL, if you cant change it on the TV, with the decoder remote press menu then 7 then 4, it will ask for a pin code press 9-9-4-9 it will read "RF modulator" press OK, it will then read 1 MODULATION press ok again and it will highlight PAL I now press the right key and press OK, if this persists then the decoder it probably faulty... good luck
