MY KONIKA MINOLTA BIZHUB 165E PROBLEM CAUTION MACHINE TROUBLE SERVICE CALL C 2558
SOURCE: konika minolta
CDC## Appears to be trouble related to security.
The only solution is to contact Konica Minolta to find out what needs to be done to resolve the problem.
That is only solution the service manual has provided.
SOURCE: machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
SOURCE: How do I clear error message C-2558 for the Konica
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
SOURCE: my bizhub 210 is coming up with an error mesage
its the code of ATDC sensor, that means your machine is having low deveolper, kindly change the developer to permanently get rid of this code. thanx
