Hi there.........i take it this is a used / second hand wine cooler......if so you've probably discovered why its been discarded........problem could b due to a faulty compressor unit....the fans are usually wired through the compressor...and run in conjunction with it........if the compressor isnt running then the fans are out .........if the comressor is running then check that there is nothing impeeding the fans rotation.....check for broken or damaged wiring.....check for tampering by someone else....check continuity of wiring through fan coils.........check for faulty starter unit on compressor
regarddss ir Galahad
Is there a services number for haier
