proceed using the common sense. You must open the microwaves for to see what happen, the coffee produce bad contacts, and reaction from component like short, etc. However the following. God bless you
Door Switch
If the microwave runs for a few seconds and
then shuts off, a door switch might have failed intermittently. Check
each of the door switches for any signs of overheating, arcing, or
burning. Also check each of them for continuity. Replace any of the
switches that is visibly damaged or that only has continuity
intermittently.
Main Control Board
stops there may be a short circuit in the main control board. Check
other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
stops the touchpad and control panel might be defective. There are
several other components that can cause this problem, be sure to check
any other components before replacing this board.
Touchpad
stops the touchpad might be at fault. This is not common. Generally
speaking, if the dishwasher display is working and some of the buttons
respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
stops the high voltage transformer might have an intermittent short.
This is not common. Check other components related to the microwave
symptom first.
Thermoprotector
stops the thermoprotector may have tripped. This is a safety device to
prevent the microwave from overheating. It can be tested for continuity
to see if it's blown.
Thermostat
stops the thermostat might be defective. Watch our video on testing
thermostats.
OF COURSE I CHECKED THE OUTLET. IT IS LIVE.
