I can't connect to internet through my SAMSUNG s3310 mobile.i want to surf internet in my PC with this mobile,I also try SAAMSUNG PC Suite for this.But when I try to connect to internet it shows a message "OS error,PPP link control terminal terminated..."...Plzzzzzzz....help me......
Make sure that you have the correct settings for GPRS or 3G, call your service provider and they will send you the correct settings for free.
See pc suite help guide to connect to internet, from ur s3310..
and call ur toll free service provider to send the settings for s3310 to connect to internet..
when it is received,u can install it..and wow u can see internet on ur laptop or pc through s3310
DONT FORGET TO RATE,..
IF ANY NEEDED MAIL ME
[email protected]
How to connect internet in the samsang metro s3310
Tell me your network provider that i can help u
Samsung PC Suite - Internet through mobile modem -Error 619 - Data Cable
Rectifying the error
1. Samsung USB modem driver (Download from Samsung ' Local Link)
2. Connect Your Samsung with a working Internet connection ( via )USB Cable
3. Samsung PC Studio or any other Samsung mobile drivers are not installed
Procedure
1. Connect your Samsung Star 3G to your PC and install the modem drivers that you have downloaded.
2. Goto Control Panel > Phone and Modem Options
3. Select the Modems tab. You will see Samsung mobile modem listed.
4. Select it and click on Properties.
5. Goto the Advanced tab and put the following in the box for Extra Initialization Commands:
+cgdcont=1,"IP","your_apn_name"
( or tye AT+CGDCONT=1, "IP', "apnname")
eg:- +cgdcont=1, "IP", "bsnlnet"
6. Hit OK and exit.
The next step is to create a dialler for your Samsung Star 3G mobile modem.
Error 619 solved
1. To create a dialler, Goto Control Panel>Network Connections
2. Hit Create a New Connection and proceed as follows (each sub-point is for each screen of the wizard):
2.1 Network Connection Type: Connect to the Internet
2.2 How do you want to connect to the Internet: Set up my connection manually
2.3 Select Connect using a dial-up modem
2.4 Select Modem-Samsung Mobile Modem
2.5 Type an ISP name according to your preference (could be anything)
2.6 Type*99# as the phone number ( or type *99*1*1# or *99***1# )
2.7 Leave Username, Password and Confirm Password fields blank
2.8 Hit Finish
That would complete the wizard and make a dial-up connection for you. Dial it and you will be connected to the Internet via your Samsung Star 3G phone modem without using Samsung PC Studio
