Hi, W/D here.
Try something else in the outlet. Most kitchens have ground fault outlet circuits, so you may have a tripped outlet breaker. These type of circuits can come from the panel through a ground fault circuit breaker, or they can go to the first outlet on a run of outlets. If the first outlet is ground fault protected, the others on that same run are protected as well. If another device will work in your coffeemaker outlet, the coffeemaker is probably dead. If another device will not work in the outlet, and your coffeemaker will work in a known, good outlet, you'll need to look at all of the outlets in your kitchen and bathrooms for an outlet with a "test" and a "reset" button on it. If your outlet is on that circuit, you will need to push the reset button to restore power to your coffeemaker's outlet.
Best regards, --W/D--
Testimonial: "thanks, sounds like my favorite coffee maker is dead.Due to the storm and sever lighting."
