SOURCE: Mower will not start. Makes a loud fast clicking noise when the key is turned.
Loud ticking usually indicates near dead battery, take it out and charge it. If it still ticks you may need to replace it as they are only good for a few years.
SOURCE: lawn mower needs new cord to crank the engine. how do i replace the cord
Remove the 3 bolts located on the flywheel housing.(should be 7/16") one in front and two on side.
SOURCE: lawn mower has a loud noise like something is
Sounds like your deck may be bent in and the blade is hitting. Remove the sparkplug and tilt the mower back on the handle (I'm assuming this is a push mower) and have someone pull the rope while you watch the blade underneath. You should see the problem.
SOURCE: Lawn mower will not stay cranked unless you keep pouring gas into
common problems to all older lawnmower, lots of dirt and dust the mower goes through and ages. I would first start by taking the carb apart and clean the filter with soap and water, allow it to air dry. also carburetor prob need rebuilding or replacing. Pick up some Carburetor cleaner at any auto part store and spay it down the carb, dont be afraid to spray allot in there and let it dry for 1/2 and hours. carb tend wear and parts need replacing just like any engines. 99% of the time lawn mower carb goes out before the engine will and common problems with all lawn mower. If you not mechanical incline or dont want to rebuilt it, just buy the whole new carb and replace it, fairly cheap easy to replace and will last you another 10 + years or more. www.briggsandstratton.com
Testimonial: "This guy really knows what he is talking about. I would highly recommend him."
SOURCE: I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
