Tilia Foodsaver V835 Vacuum Sealer Logo
Posted on Aug 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Foodsaver vac1050 wont stop runing go to 3 bars thats it
Foodsaver 1050
Lee Eismann
Level 2:
Novelist:
  • Expert 88 Answers
  • Posted on Aug 02, 2010
Lee  Eismann
Expert
Level 2:
Novelist:
Answers
88
Questions
Helped
72893
Points
256
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
  • raymone31 Dec 08, 2010
    I used a little olive oil and it worked great as well! Thanks for the tip.
  • Anonymous Dec 02, 2017
    I don't recommend olive oil since vegetable oils like this will go rancid and sticky when oxidized, and will likely degrade the foam as well.
Foodsaver vac 1050
Perhaps the bags you are using are not suitable. If they are too thin it will not vacuum air out.
V65 magna was runing 2 bars on temp gauge and now it runs 5 bars
The V65 should run on 3 to 4 bars, When stop & go traffic it will run 5 or 6 unless you have installed a fan switch so you can turn the fan on, If it ever hit 7 shut it down but 4 should be right on the right temp, I have never seen a V65 run only 2 bars, Something was not right causing this.
Need to find new heater bar for a game saver turbo
You can try the customer support number:
877-777-8042
FoodSaver's customer support website:
http://www.foodsaver.com/Support.aspx?id=sfaq&fgid=21
If you get nowhere with this, you could check to see if a thermal protection fuse is blown. Most electrical appliances that involve heat have a small thermal fuse that can be purchased at most Radio Shack stores. It's a small thing, about 1/2" long, with a cone-shaped end and wires coming from each end.
I hope you can fix this. Good luck.
Feb 17, 2011 • Vacuums
4helpful
2answers
I am on my 2nd foodsaver. My 1st one stopped working, which I later found out, was probably due to the bottom gasket. My 2nd one had the same problem. I called FoodSaver, and they suggested that I flip...
I replace my gasket with a piece of 3/8" Poly Foam Caulk Saver (found mine at Home Depot - @$2.00 for 20'). It's a snug fit in the gasket groove. Cut long enough so that the ends touch tightly. It will create a good air seal and works well.
1helpful
My sealing gasket is broken and it will not seal my food anymore. model 1050
Replacement parts for your product may be ordered online here:
http://www.foodsaver.com/Category.aspx?id=r
If you are unsure which gasket to order contact FoodSaver via their website:
https://secure.foodsaver.com/ContactUs.aspx
I need the lower rubber on my 1050 foodsaver. Any ideas
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, and Installation Instructions as required.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
I hope this helps.
4helpful
My Foodsaver Vac 1050 doesn't extract all of the air from the bag
Either the sealing strips are dirty letting air escape or the lips of the bag are turned upwards. Push the front of the bag down towards the bottm chanel and it should work fine. I have had one for eight years now and love it.Ken Vancouver BC
Top Tilia Kitchen Appliances - Others Experts
john h
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
