I just had a new-to-me wall oven installed. It was apparently working correctly when taken out of a house during a remodel and I was hoping for a relatively inexpensive replacement for an old wall oven. When trying to set the clock, we noticed that the display moved too quickly, making it impossible to set the time.
I could live with that, but then noticed that the same thing happens when trying to set the temperature on the bake setting--it will jump from 170 to 400 to 550 and back down randomly as soon as the up or down keys are pressed, as if the keys are too sensitive. The oven heats--problem is in the touchpad. Any solutions? Thanks for your help.
I don't see that exact model number listed. Check the model / serial number again. If the unit is not too old, you can probably get a replacement key panel which should solve your problem.
