Lexmark X3330 All-In-One InkJet Printer Logo
Posted on Aug 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I install scaner lexmark x3330 on vista64 bit but it does not, it s mean the port usb no recognize lexmark x3330. What Can i do?
Anonymous
Level 3:
President:
  • Master 1,383 Answers
  • Posted on Aug 12, 2009
Anonymous
Master
Level 3:
President:
Answers
1383
Questions
0
Helped
531683
Points
4395
Right click on my computer icon then clcik on proeprty then hardware 0>device manager
then uninstall all usb drivers then restart the computer .
If still face problem then change usb cable.
If still same then when you power up the computer press F1 or f2 or 'del' key to enter in bios then go to advanced then usb enable usb legacy 2.0 then save settings then check.
Lexmark x3330 can not upload because my computer says it is existing in a older version, but does not appear on any folder, you can install it because I lost the installation cd? (was cofigurat computer...
Try this approach instead. On your computer, go to Start menu > Programs > Lexmark 3300 Series folder > Tools > Uninstall. Your computer will then start the uninstall process. After successfully uninstalling the printer software, reboot your pc when prompted.
When your computer turns on, re-install the printer driver. Please visit the Lexmark website to download the Lexmark 3300 Series printer driver on your computer. Use the Vista driver for Windows 7. Select the corresponding driver for your operating system version. Simply follow the instructions on your computer screen to complete the installation.
2answers
"No communication with Computer" message.
hi Margaret,
have you considered reinstalling the drivers and applications for this Lexmark printer ?
if you need the drivers (compatible with WINDOWS VISTA only operating system), go to this link
http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_X3330&focusedTab=DOWNLOADS#1
hope this helps
I had same problem, even if I download de cjb3500_4500en the processo goes on but when I put to configure wifi (orange) they ask me to put a usb cable, but on actives the button do continue if the USB was...
You did a nice job trying out other ways to install the printer successfully. However, it's weird that 3 computers are not recognizing the USB connection. Make sure that the USB cable is plugged in correctly (in the right position) in the USB port of the printer.
Next, use the correct driver that is compatible with your computer's operating system. You may need to uninstall the existing software before reinstalling the new one. Instructions on how to uninstall the Lexmark software available at http://bit.ly/8ZH59T. Then, you can download the drivers at:
If problem continues, contact Lexmark technical support.
2helpful
2answers
Lexmark P6250 won't scan in Vista64
Disconnect the printer or at least be sure it is turned
off. I'd do both and reinstall the CD software program
that came with the printer.
When the software program asks you to
connect the printer to the USB port, do so and it
should again work properly.
Hope this is of some help. Bud
Lexmark x3330 for linux
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Misplaced disks to install programs for printers Z611 & X3330 can anyone help
If you want to buy the replacement disk you can
Contact Lexmark here, to see if the disk for your printer is available.
If instead you want to download the software for free , click here and enter your model (Z611 & X3330 ):Official Lexmark Drivers and Software
Misplaced disks to download programs for printers
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printer does not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
