I want to remove sd for nhzns w5776030
So as to keep songs
I have the a Casio Keyboard that has an SD slot, but whenever i put songs on my SD card & then plug it into the keyboard, it says that there is an ERROR . What am i supposed to do . Step by Step . to...
Does it say ERR NO FILE? If so, then read on. The reason you have this error is because you don't have a folder on your sd card named MUSICDAT. Solution:
  1. Insert your sd card into computer
  2. Make folder called MUSICDAT.
  3. Then, transfer all files inside the folder (make sure your songs are in MIDI format).
  4. Safely remove your sd card.
  5. You're ready to put it in you Casio Keyboard!
If you still get the error, take time to read you manual. Read the "using the sd card" part. The folder name might be different for your Casio Keyboard (because mine's a CTK-5000).
...and IF you still get the error, perhaps the songs you meant in your question are MP3 songs (like the ones you play on the iPod)? Then, that's a different topic... :)
Well then, good luck!
Feb 28, 2011 | Casio Lighted Keyboard LK90STADMC
Downloading songs from an i-mac computer to a garmin zumo 660
I don't know for sure, but most likely the problem is that iTunes keeps songs in AAC format, and the Garmin wants them in MP3 format.
If that's the case, then what you need to do is this:
in iTunes, build a playlist of the songs you want to export.
Click on that playlist to show the list of songs
Click on the first song in the list, then hold SHIFT and click on the last song in the list so they're all highlighted.
Select the menu option "Make and MP3 copy". Apple keeps moving this option, so you may have to hunt for it, depending on the version of iTunes you have.
This should leave the nice-quality AAC versions alone, but also make MP3 copies of each song.
Copy the MP3 files to the SD card and try that in your Garmin.
Jun 06, 2010 | Garmin zumo 660 GPS Receiver
Just bought Kingston 2GB SD Card for Boss Micro BR but when maching turned on,its frozen on KEEP POWER ON! SONG LOADING!
This is likely a compatibility issue. Turn power off and remove the card and make sure the unit comes back to life.
SD card compatibility can be a problem.
You might want to go to VSPLANET.com as there is a lot of info on forums about recorders.
Jun 03, 2010 | Boss Micro BR Digital Recorder
REFUSES TO PLAY SONGS
turn on the ipod and go to explore files, and see if the music is there.
May 27, 2009 | MyMusix PD-201 MP3 Player
Forge not recognizing SD Card
the socket where card is installed may have internal loose element so its not detecting.check out the card in another device and also check another card in your device.this will confirm the fault.
Mar 06, 2009 | Rio Forge Sport Digital Media Player
Samsung instinct, Micro SD card can't remove music. write-protected?!?
Usually you should be able to take the SD card out of your phone and put it in a universal card reader (around $30.00 cost) connected to you computers USB port. The SD card will come up as an external drive icon on your desktop. When you open the SD card icon on your desktop by clicking on it the contents of the card should be right there visable. Just drag whatever you don't want on the card off the card and into the trash. It should no longer be on the SD card when you reinsert it in your phone.
Nov 05, 2008 | Cell Phones
SD Card not showing in my Tomtom go 720 to play MP3
If you want to play mp3 songs from sd card then create mp3 folder and place all the songs in side that folder. Now when you go to Juke box menu it will scan all the songs and you will be able to play them the way you want..
Jan 09, 2008 | Tomtom ONE GPS Receiver
SD card in MP3 player
Was the SD card in the MP3 player when you loaded the songs or did you load them some other way?  You may have to first put the SD card in the MP3 player first, then load the songs onto the player.
Jul 03, 2007 | RCA M2000 MP3 Player
22 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
