The coaxial cable connector got pulled out of the chrome box and took part of the circuit board with it.
If by circuit board you mean a piece of copper circuit track it is still quite possible to repair quite cheaply.
If you mean a real part of the circuit board from the actual silver box (demodulator) then again these are pretty common and not too expensive to get hold of and repair
If however you mean part of the main circuit board for the TV it may be possible to repair bu you may be looking at more cost than you wish to spend.
If you feel competant in soldering then the first two are pretty simple.
You would either work out what part of the track was broken and run a small lead from where it is on the board to where it was supposed to go.
If its the silver box there are numbers on it from which you can order a new one, remove the old one and simply replace.
If you found this information useful then please click below
Ok so we establish its the demod box that is pooched dont forget that when working in a tv there is still plentyof chance to get a good ZAP ! experience dont ya know !
Ok first off you need to work out tha manufacturer of the demod box because most tv makers just buythis bit off the shelf there is usually a model number or other numbers stamed even on the box and is these you need to run through google. you may also want to check some of the online proper electronics parts suppliers. If you are in the UK or europe you are off to a flying start because a lot of these guys actaully carry stock or equivelants
If you are anywhere else you may have a little more digging to do
But just to get you started
http://www.partmaster.co.uk/cgi-bin/cata...
http://www.alltronics.com/cgi-bin/catego...
http://www.surplustraders.net/a/0121.sht...
http://www.partstore.com/Search/Model/Ma...
If you found this information useful pease click below
Bob, yes, the demodulator has a circuit board inside....as you know. Ive soldered plenty of f-conn. back, but Ive never seen one that actually took out a corner of the printed circuit board. This board has so many solder points per sq. in. there is no way it could be reattached. Do you know where I can find parts. pls advise
