SOURCE: Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
SOURCE: How to unlock the frigidaire oven range door and
How do you adjust the oven door on a Fridgedaire Gallery Series gas stove?
SOURCE: Maytag Performa Advanced Cooking System,
says F1 will not stop beeping. unpluged and waited still beeping!
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
