Hello jlharris28, Here's the color code for the '92 Sentra: Radio Constant 12V+ Wire: Red/Black Radio Switched 12V+ Wire: Blue Radio Ground Wire: Chassis Radio Illumination Wire: Red/Blue Radio Dimmer Wire: Red/Yellow Radio Antenna Trigger Wire: N/A Radio Amp Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): Blue/White Left Front Speaker Wire (-): Blue/Yellow Right Front Speaker Wire (+): Brown Right Front Speaker Wire (-): Brown/White Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Red Left Rear Speaker Wire (-): Green Right Rear Speaker Wire (+): Blue Right Rear Speaker Wire (-): Pink It's better to use an aftermarket wiring harness that plug into the vehicle wiring. The Metra part number 70-1763 seems to be the correct one for your vehicle. Hope this helps.
Testimonial: "thank you greatly. that does help alot."
That CD player would appear to have only 2 channels and have a common negative for the speakers. I've never seen such. What is the brand and model number?
Anyway, the power antenna wire would be connected to the Red/Yellow and ground to any metallic surface of the vehicle frame. Usually you can find a screw near the radio. It's best to use a spade terminal. If you can't locate a convenient screw to back off a couple of turns and insert the prongs of the spade terminal, you can drill a small pilot hole and use a self-tapping metal screw.
I'm trying to change my 2003 Ford Thunderbird audio system.
I have bought a FWH600 harness however some of the wires on my aftermarket audio system are not exactly matching with FWH600 wires.
Anyway I can get a list of wires functions for FWH600?
have another question for ya. the cheap cd player I have has only 5 wires. 1 lft spkr, 1 rght spkr, 1 grnd, 1 pwr antenna, and 1 12V+. I believe I can figure out most of it, but which wire/wires do I hook the pwr antenna wire to, and which one do I hook the grnd to?
