Heating & Cooling Logo
s
stephan lambert Posted on Jun 21, 2019
I have dometic rooftop ac. Worked last year when stored . This year ac doesn't work . Tried new t stat and nothing happens. Touch green wire to any other function wire and that function starts.
Possible bad control board
5 Related Answers
Anonymous
  • 95 Answers
  • Posted on Jun 25, 2008
SOURCE: Dometic Rooftop RV Air Conditioner
Possible bad capasitor, or seized motor
Anonymous
  • 828 Answers
  • Posted on Jul 24, 2008
SOURCE: Circuit Breaker and Dometic Rooftop RV Air
Since your RV A/C works O.K. when plugged in to the land line and the trip happens when you run it on your generator the problem may be related to the generator output. It is possible that the power being supplied by the generator is not handling the surge when the A/C starts. Starting Amperage on start up is about 5 times the running Amperage for about 3 seconds until the compressor comes up to its rated speed.
Anonymous
  • 16 Answers
  • Posted on May 21, 2009
SOURCE: We have an older model (58SG100251) installed in the attic. With the thermostat set & turned on nothing happens. A new blower motor was installed last year.The t/stat is a ritetemp digital. I,ve c
Possible fan relay is defective, does outside unit come on ?
Anonymous
  • 127 Answers
  • Posted on Jul 04, 2009
SOURCE: Relay (?) sticking Dometic RV rooftop AC
Go up on the roof of the unit and remove the AC Shroud. With the unit running, see if you can pinpoint where the sound is coming from. The only thing on the entire AC that would make that much of a vibration would be the fan motor. Not sure what would cause the fan motor to do this. The compressor may do that but only if the windings are bad and then it would not be cooling.
Anonymous
  • 59 Answers
  • Posted on Apr 21, 2010
SOURCE: How to identify the btu of rooftop AC unit
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
Is this a thermostat problem or system failure?
it sounds like no communication from stat to board. cable connections
Runs/cools great unless outside temp gets in high 80s
try replacing capacitors. or communication cable issue to that a/c
1helpful
Multiple clicking sounds coming from AC unit before AC unit turns on or before furnace turns on.
the is a 24v wire that feeds from your thermostat to your unit, inside there is a contactor that engages, this makes a click sound as it really is a basic mechanical part the makes metal touch metal to allow current to flow through the system, perfectly normal, your hearing the low voltage engage the highvoltage at the contactor.
Dometic rv ac fan does not run compressor does
fan relay bad ,bad capacitor cable between t-stat and relay module not making good contact.
1helpful
Crazy Heat
I think that I would change out the thermostat only due to the symptoms you are describing. Think the control board may be fine however, the thermostat sounds as if the internal componants are going out. Good luck on your repairs
Dave
1helpful
Dometic AC fan mode or cool mode wont start. Has a climate control t-stat, lights up.But nothing on AC ?Whats with phone line connection ?
Some manufacturers use phone line to use as communication between control box on AC unit & thermostat. (very common.) Make sure 120VAC is on, and pull cover off thermostat & look for a glass type fuse possibly blown.
2helpful
RV A/C COMPRESSOR RUNS CONSTANTLY
You must isolate the problem by disconnecting the thermostat wires that go to the unit. If the compressor does not run when the t-stat wires are disconnected, that shows that the t-stat is malfunctioning, or there is a short in the wiring between the t-stat and the ac unit.
If the unit continues to run after disconnecting the t-stat wires, then you'll have to look in the unit for a stuck relay
2answers
Its the watts you plug in too like ither 30 watts vs 50 watts. 30 watts will cause your wires to get hot in the unit. just pull down your breaker box and look at those white ground wires.
Top Dometic Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
