SanDisk SDMX1 MP3 Player Logo
Posted on Aug 12, 2009
My SDMX1- 256MB can turn on but doesn't play and turn itself off
I have a SDMX1-256R v2 (256MB).when i press the on button it show me hall but it turn itself off after a few second
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Jul 22, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
748
Points
10
Dont know what "hall" is, and im guessing the battery isnt dead---might need to format it
1helpful
I have an error message f51 on my whirlpool cabrio washer model number WTW7600XW0, What is it and how can I fix this error on my own
F51 error code is a motor rotor position sensor failure or a lower harness problem. You need to check the motor in manual test mode, not automatic test mode. This will check the hall sensors and do a spin test: Be sure the washer is in standby mode (plugged in with all indicators off; or with only the Clothes Clean or Done indicator on). Select any one button (except POWER, START, STOP, and PAUSE/CANCEL) and follow the steps below, using the same button: Press/hold 3 seconds. Release for 3 seconds. Press/hold 3 seconds. Release for 3 seconds. Press/hold 3 seconds.
If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display. During the 5 second wait time with 88 showing in the display, press the same button once. You should be in manual test mode. If the button is not pressed within 5 seconds, the automatic test mode begins. The Rotor Position Sensor uses Wash, Rinse, and Spin indicators to detect the three hall sensors. Console can have up to two of these indicators on at the same time when the tub is not moving. Open the lid and rotate the basket by hand. The Wash, Rinse, and Spin indicators should toggle on and off according to the direction the tub is being turned.
SPIN TEST: Make sure lid is down. Press and release: 2nd RINSE or EXTRA RINSE. The lid locks and the lid lock indicator turns on. Press and release; SPIN SPEED, WATER LEVEL, or LOAD SIZE. The motor/basket spins at 23 rpm. Press again, motor /basket spins at 530 rpm. Press again, motor/basket spins at 950 rpm. Press again and motor turns off.
What does error code f 51mean?
http://www.applianceblog.com/mainforums/threads/32879-Whirlpool-Cabrio-UL-F51-Error-Codes
How do I fix a f51 code on a whirlpool cabrio washing machine
SPIN TEST: Make sure lid is down. Press and release: 2nd RINSE or EXTRA RINSE. The lid locks and the lid lock indicator turns on. Press and release; SPIN SPEED, WATER LEVEL, or LOAD SIZE. The motor/basket spins at 23 rpm. Press again, motor /basket spins at 530 rpm. Press again, motor/basket spins at 950 rpm. Press again and motor turns off. This was a cut n paste from a blog on that issue.
2helpful
I have a lg tromm wm2277hb and it's not spinning. The le error code is coming on. I tried to unplug the unit and press and hold start button and then the power button for 5 seconds. Then tried the...
Hi
Error code LE indicates that either the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure it's not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn't move freely then the motor is locked and you'll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Hope this helps...
Daniel
2helpful
I just got an mp3 player. its a Trio V2 SL. I cant figure out how to turn it on! I did read the directions.
Use the "ON/OFF" switch at the top of the unit. Switch it to "ON", then press and hold the "Play/Pause" button for 5 seconds, and it should turn on.
IT TRIES TO POWER UP THE FANS TURN FOR A WHILE THEN IT SHUTS DOWN
Turn off the monitor before pressing the power button, if the doesn't work, try unplugging the monitor completely before pressing the power button.
2helpful
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
2answers
Dish 625 DVR recorder won't play recorded shows. It gives me an error code (05)
Hi I will be more than glad to assist you in this concern. First press the power button on the front panel of the receiver for 10secs. once you press it the receiver will turn off and it should turn on by itself, once it turns on by itself you will see attention 015, press the menu button on the upper left of the remote, once you see the menu button press 6, 1, 1 on the remote and it should show on the screen point dish, select on check switch, once u are on the installation summary screen, select on test and it should do a test of 1 of 3 or it depends on your sat orbital location that u have.. once its done, it will show the installation summary screen and you should see sat input 1 & 2 with port1 up to 2 or 3 depends on your sat orbital location, all the trans on the sat 119, 110 or 129 if you have should be ok and green. once you see that all ok, select done on the screen, and it will be back to point dish, select done again, and then cancel all the way out of the menu, it should show on the screen attention 015, let it finish until it download the programming guide, once its done it should show a tv pic. press the dvr button and access your recorded event, it should play the dvr event. if the problem still exist, unplug the power of the dvr from the power outlet for 1 minunte then plug it back again and it should acquire the sat signal and download the programming guide, once it shows a pic. press again the dvr button and access the recorded event. it should play the recorded event, just incase the problem still exist, check what will be the exact error msg, write it down in a piece of paper and please feel free to get in touch or you can call on 1-800-333-3474..in order to for the dish tech support replace the receiver, this is a dvr lost of function.
WIRELESS KEYBOARD caps and niumber lock status
The MS Keyboards and Mice 700 v2 receiver has a reset Button under the word "Microsoft" press this button and then while its flashing press the connect button under the mouse! ALL Fixed
1helpful
How do I downlaod to a Sandisk MPS player modeil # SDMX1-256R v2? What media platform do I need?
(to clear or 'erase' skip to format -below)
1ST: Just try to 'reset' by holding down the main center button AND pushing UP on the lock/off-on button, for about 8-9 seconds,
It will then 'refresh' the database, shouldn't lose anything,
OR:
Most other problems can be fixed ultimately by the following;
REFORMAT the SansaDisk Clip by finding it in My Computer and right click then just 'format' the thing. THEN drag and drop new music into it (or books), DRAG and DROP, you apparently erase the thing with a 'FORMAT' ....BUT - it's .sys files remain and it is like new {as in empty}
This usually fixes almost anything, should even erase a virus (I'm guessing) but shouldn't hurt it.
Good Luck!
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
