Sharp Viewcam VL-Z3U Mini DV Digital Camcorder Logo
Posted on Nov 29, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sharp Viewcam z
Anytime I put on my camera it shows a dew indicator and goes off. What can I do To get round this problem?
  • george1950 Aug 17, 2008
    I have a Sharp veiwcam z and have taped about 4 hours total so it is almost brand new and now I consistantly have DEW message on screen.
    Tried new batteries this does not work
Anonymous
Level 3:
  • Master 752 Answers
  • Posted on Nov 29, 2007
Anonymous
Master
Level 3:
Answers
752
Questions
0
Helped
393243
Points
1932
Either it has moisture in it (let it dry), or the dew sensor is bad and needs to be replaced.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 02, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3608
Points
7
When i switch on camera only white light comes noo display what is the problem
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 22, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3097
Points
Anonymous
Level 1:
  • Posted on Aug 24, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3097
Points
I had the problem with my vl-z1 the dew indicator,i used a hairdryer to solve the problem. ( take tape out turn dryer on low setting,and place dryer about 8"to10" away from camara,let run about minutes.) hope this helps
2answers
My digital camera wont work and it keep saying DEW. what does that mean? it is a sharp vl-z5 digital camera
I HAVE A VIEWCAM VL-Z7, I STARTED TO CHARGE MY BATERRY TO THIS JUNKY UNIVERSAL CHARGER AND FOR SOME REASON IT TURNED ON BUT 1 MINUTE LATER IT TURNED OFF AND NEVER TURNED ON AGAIN
WILL NOT HOLD A CASSETTE. VIDEO ERROR READS
normal dew indication is from moisture if you can find any desicant out of pill bottle sometimes in new electronics the desicant can be ractivated by placin in oven at 220 degrees basically above boiling point
15 to 20 minutes let desicant cool place camara and desicant in tight sealed container or plastic bag let set overnight see if moisture problem goes away
2answers
"DEW" on the screen
its showing that because it stands for something taht u can read up on in the manual
Bypassing of DEW sensor
there is no way to bypass it, but simple modification is available to correct this problem. contact any sharp authorized repair center.
9helpful
2answers
What doe DEW mean? The "DEW" sign keeps coming on and then shutting off..
DEW sign indicates high humidity level inside the camcorder. What you experiencing has nothing to do with humidity, It is a faulty connector on a junction board. Sharp has fix for it.
DEW indicator / battery
In your owners manual on page 52 you will find a list of authorized service centers. Give the one in your area a call. Give them the brand name and model number of the camcorder. Tell them you are having a problem with the dew warning coming on while using the camera with the battery. They should be able to help find a answer to this problem.You can also call the panasonic customer support telephone number at 1-800-211-7262 between the hours of 9am-7pm EST. Give them the brand name and model number of the camcorder and ask them for help with the problem of dew indicator coming on while in use with the battery. I hope this information helps you with your camcorder problem.
2answers
Dew indicator
look inside the camera to the front.wou will see 2 solder bloba,run a line of solder between them to by pass the dew,it works
2answers
I get the DEW indication and cam shuts off
try to dry up your camera using electric hair blower drier, dew is present inside your camera, but dont overheat the unit, place your hand between drier and cam to make sure you are not overheating it. if the trouble is still there, the sensor is defective and you need pro fix.
1helpful
E007 and DEW indicator
Few restarts fixed this for me but I know this is going to come back again soon.
1helpful
2answers
The "DEW" indicator is illuminated on my Viewcam, what do I do to turn it off?
This means there is moisture inside the Viewcam. Try taking the tape out, leaving the cassette compartment open for 2 hours to allow any condensation to evaporate. If the DEW indicator is still illuminated call a Sharp authorized servicer.
Top Sharp Video Cameras Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
