Linksys WRT160N Wireless Router  Logo
Posted on Aug 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just got a Linksys WRT160N router. I cannot connect to the internet using the ethernet port in my pc. I can, however connect via a wireless card in a USB port. I can also use my digital video phone. When I run cmd - ipconfig/all this is what I get: Windows IP Configuration Host Name . . . . . . . . . . . . : mpg Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Broadcast IP Routing Enabled. . . . . . . . : Yes WINS Proxy Enabled. . . . . . . . : No Ethernet adapter Local Area Connection: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : SiS 900 PCI Fast Ethernet Adapter Physical Address. . . . . . . . . : 00-50-2C-02-B0-97 Dhcp Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 192.168.0.1 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : Ethernet adapter Wireless Network Connection 4: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : IEEE 802.11g USB Wireless LAN #4 Physical Address. . . . . . . . . : 00-11-A3-00-41-87 Dhcp Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IP Address. . . . . . . . . . . . : 192.168.1.103 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.1.1 DHCP Server . . . . . . . . . . . : 192.168.1.1 DNS Servers . . . . . . . . . . . : 209.18.47.61 209.18.47.62 Lease Obtained. . . . . . . . . . : Tuesday, August 11, 2009 9:05:27 PM Lease Expires . . . . . . . . . . : Wednesday, August 12, 2009 9:05:27 PM I can successfully ping 192.168.0.1 as well as 192.168.1.103 It seems that the problem must exist with my ethernet port/driver...correct?
crazytony777
Level 2:
Sergeant:
Champion:
  • Expert 257 Answers
  • Posted on Aug 12, 2009
crazytony777
Expert
Level 2:
Sergeant:
Champion:
Answers
257
Questions
0
Helped
81515
Points
640
You are right, need cd for you lan card for it to work right,,but if you dont have it go to linksys web site and download the files you need
3 Related Answers
Anonymous
  • 11 Answers
  • Posted on Feb 16, 2010
SOURCE: Laptop connects to wireless with Erthnet cable but
RE INSTALL THE LAN DRIVERS AND DISABLE THEWINDOWS FIREWALL
Anonymous
  • 10406 Answers
  • Posted on Feb 21, 2011
SOURCE: D link router connection Hi I have recently bought
Everything looks normal:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-1D-D9-44-F8-15
DHCP Enabled. . . . . . . . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::1c05:824a:4808:dd81%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.102(Preferred)
Lease Obtained. . . . . . . . . . : 21 February 2011 13:48:48
At the command-line prompt, try: ping www.ucla.edu
If it responds, then you *DO* have a good Internet connection.
Anonymous
  • Posted on Feb 26, 2011
SOURCE: I am trying to wirelessly connect to a netgear
I am having exactly the same problem - driving me mad! It seems it does not pick up the ISP addresses.
2answers
5helpful
My router is connected, but there is no internet connection.
Actually, Linksys WRT160N is meant to be used as a router not an access point. It can be but with at
Cannot get wirelss connection through my WRT160N wireless router. Was working and now not. I can get internet connection through the LAN ports so I know that the router is working with a fixed cable
by default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every setting
Can't get wireless connection from PC to Linksys WRT160N
To setup a wireless connection on a computer, the wireless card in the computer needs to be configured with the wireless router's settings.
For instructions click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
2answers
Linksys wrt160n will not broadcast the internet wireless or ethernet it will however broadcast a connection to the router not the internet. I have tried to re-set it, power down, nothing works. I have not...
Your Linksys WRT160N is a router that can be accessed via CAT-5 cables and wirelessly. You must configure the router though, for wireless use. If this is not configured or not configured correctly, then you may have problems using it wirelessly. Laptop computers usually use the 802.11g mode, not the 802.11n, at 54MB or with the right NIC in a desktop you can get 108MB. If it was working then quit without your doing anything, you may have to replace the router, but I doubt it.
1helpful
2answers
Cant connect to the internet with linksys wrt160nv2
if this is DSL connection then you have to configure your modem before you connect router
follow this
first disabled wireless on your modem/router
.1) Turn off DHCP on your modem/router I am assuming this is verizon westell
2. Configure the first VC port to Bridge-Bridge mode
3. Keep hitting "apply" in the windows until the 7500 reboots
4. Plug the "Internet" port on the linksys to one of the normal ethernet ports on the modem /router
5. Turn on the Netgear and wait for the green Internet light to go solid
good luck if this does not work provide more info on your setup
PC will not connect unless Laptop is turned on?
first reset the connection, and try to connect the pc with switch and when net start working the connect the laptop
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
