Follow these steps to resolve the issue:
Step 1: Remove the cassette and insert it again , then operate your Camcorder.
Step 2: Try using different cassette.
Step 3: Try resetting the Camcorder.
[Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.]
Please locate the RESET button behind the LCD screen of the Camcorder. Press the RESET button using a sharp-pointed object. The Camcorder should be switched ON when you reset the unit.
Step 4: Try to power reset the Camcorder and check if it helps to resolve the issue. Power Reset the Camcorder by removing the batteries from the Camcorder and inserting it after 1 minute.
Step 5: Service is required.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C79466
