Maytag Neptune MAH5500B Front Load Washer Logo
Posted on Aug 12, 2009
My washer continues to kick off during the cycles several times a load. It isn't too much laundry. The door stays locked and I just hit the start button and it goes again. Any ideas?
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Aug 12, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
0
Helped
3018
Points
13
The belt could be to loose and the motor overload is kicking out the motor and when the motor cools off it will restart.
Front load Frigidaire Affinity washer (atf7000es) starts but does not lock door and just does not continue on wash cycle.
The lock and the switch assembly switch could be broken with your washing machine and should be replaced.
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
ā€¢
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
ā€¢
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
ā€¢
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
ā€¢
Pressing Power button cancels the cycle and stops your washer.
ā€¢
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
2helpful
Washer stops during rinse cycle and beeps at me
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Washer reads dL f and door stays locked even
try to start another cycle then hit cancel and cancel again and it usually unlocks the washer
WASHER KEEPS STOPPING DURING CYCLE AND DOOR STAYS LOCKED
Try this I had the same problem and it fixed it when the washer stops it will flash a code I got F 02 but this is really easy and need to be done I wish I had known about it sooner
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
1helpful
Control locked
Hold the 'options' and 'select' buttons down at the same time for several seconds, the thing will unlock.
And rate me pl..................
1helpful
94helpful
4answers
Kenmore Elite HE4t Washer - "Control Locked"
Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
3answers
I need help
un plug your machine for an hour if you can open the door open it and then put the machine plug back in with the door open keep it open till the machine comes on then put the program to what you want and then shut the door it then should be ok its called a reset try it hope this solves your problem
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
