SOURCE: TV shutdowned while watching and it wont power up again..
just replace your Lamp. Thats it
best regards
Circuitcity
SOURCE: My Tray Door popped open after two red lights shut down console and won't close!
Here is a great page that has a step by step process for opening your unit. (they also sell parts and mod equipment)
http://www.llamma.com/xbox360/repair/Xbox-360-Disassembly.htm
You may need a new drive, but I doubt it. After you get the Xbox open, peel off the silver tape thats on the bottom front of the DVD player, unplug the 2 connections, and lift it out. Turn the player upside down and remove the 4 screws, flip it back over and make sure that the try is lined up correctly with the mechinism.
I hope this helps. Good luck and happy gaming!!
SOURCE: Red stand by light blinking
5 blinks = lamp driver (ballast) failure.
1-468-798-14 for the 610 model
replacement is done from the back of the set, should be straight forward, keep the red ballast wires apart for best results
if a tech replaced the red tube, you have an older tv where 5 blinks is the AKB error meaning your CRTs are getting old.
