Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
When it reaches the stopping point does it stop after the wash cycle if so try pushing the switch to the lid with a popsicle stick and see if it goes into the spin cycleif it does the lid switch is bad. the washer will not go into the spin cycle unless the lid is closed and if the swich is bad it won't let the time advance
Check lid switch and kink drain if ok see if wires are on timer motor if so change timer
