SOURCE: I have a bedroom ceiling
Sounds like you could have a problem with the fan....but there is also an equaly good chance it's the wiring of the fan. Perhaps a loose connection. If you are not familiar with checking electrical connections, you probably need to call an electrician to check the wiring SOON, before there is a short. If all connections are good, then you will know it's the fan (or the remote receiver on the fan).
Hope this helps!
Chad
I had this exact problem. I bought two Home Decorator fans from Home Depot and installed them in separate rooms in my house. They have LED lights. I know for a fact that I wired them right because the model fan in Home Depot fan was wired the same and my remote worked perfectly with that fan. Both fans at my house had the same issue of the light not turning all the way off but dimming worked and fan speeds worked. LONG story short, I had another fan in the Master Bedroom that was turned on. When I turned the power to that fan off (wall switch toggled to off), both of the new fans worked!!! Now I need to figure out how to wire the Master bedroom fan correctly (9 wires in one box) but at least I know what the issue was!
