HP Officejet 5610 All-In-One InkJet Printer Logo
Posted on Aug 11, 2009
No scanning HP 5610 all in one printer on HP computer running Vis
The problem is apparently huge hp has sold printers that are not compatable with the VISTA OS.
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Sep 07, 2009
Anonymous
Contributor
Level 1:
Answers
22
Questions
0
Helped
11771
Points
28
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr20
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Aug 13, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
1420
Points
24
Go to hp's site and there are 3 specific steps, one which may work for this issue with vista!
I have an hp officejet 5610 all in one but I cannot scan into my
thatd be a software issue not all printers can work with vista
3helpful
Hp 5610 black solid line in middle of scanned or copied document
Scan or Copy a BLANK sheet of paper.
if you still have that black solid line it means there are two possibilities:
>> the scanner glass is not screen
OR
>> the scanner is faulty.
Clean the glass properly using a moist lint free cloth.(do not use alcohol)
if the issue still persists
The only option that you have is to get the printer replaced.
If your printer is still under warranty(i.e if its still not an year old) you can get a free replacement from HP.
wherein they will send you a new printer absolutely FREE OF COST
if its not in warranty then you can opt for the UPGRADE option that HP has.
You can send them this faulty printer and get a LATEST PRINTER at a huge discount..
here's the number to call
1800-474-6836
2helpful
3answers
How can I scan to a PDF file? I am using HP Officejet 5610 printer
To scan a document to PDF using HP Officejet 5610, try the following,
1.) Click the "Scan paper" icon to select HP Officejet 5610, and then scan documents from the scanner
2.) Click the "Build to One PDF" icon to create a PDF document contains all of the scanned documents.
Please let us know if that was helpful enough.
Good Luck & Thanks
Shiv.
3answers
My hp 5610 won't scan with my laptop running VISTA
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
ab29
Whenever i try to scan, i get a message saying there is no scan options
Was having the same problem. I was however able to scan using the HP Solution Center. My solution was to make sure "HP Digital Imaging Monitor" was running. I found mine in: C:\Program Files\HP\Digital Imaging\bin The program name is: hpqtra08.exe It has to be running befor you turn on your printer. It's use is to allow you to scan to your computer without using the HP Solution Center.
4answers
k24674
Grand Canyon Tech
Grand Canyon Tech
