Swiss Army Wenger Sportedge Bracelet Watch Logo
Posted on Aug 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My watch the bezel that you change the time / date with, when pulled out comes all the way out, can not change time. Watch less than a year old, can not find the warrenty, not the end of the world, do not mind paying for repair
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Aug 11, 2009
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1813482
Points
13579
There are two possible causes: settting lever in your watch is broke/out of engagement or stem is broke. Not a big deal, but watchmakers skills are needed to fix it, as watch must be dismantled.
Any decent watchmaker can do it, so, just find your nearest watch repair shop and ask to fix it. Prices may vary, but no more than 25% of the cost of watch itself.
P.S. It is called Crown or Winding Crown (you say bezel).
Rate me, please.
How do I set the time on an old Regina pocket watch. I can wind it and it runs well. The piece to wind the watch does not pull in or out to set the hands.
If you can wind your pocket watch using the crown, but you cannot see any way of setting the watch, you probably have a "lever-set" movement, though it's possible you might also have a "pin-set" movement. Do you see a little button you can push in, either at 1-2:00 or 10-11:00 on the watch case? If you, you have a pin set watch. Push and hold that little button in while you twist the winding crown, and that will let you set the time. End of problem.
Setting the time on a lever-set watch is a bit more complicated and will require taking off the front bezel of your pocket watch--the metal ring that holds the watch crystal in place. Pocket watch cases of this time are usually made in 3 pieces: the bezel, the main case body, and the back. The procedure used to remove your bezel depends on the type of watch case you have.
Take a close look at the front of your pocket watch. Do you see any hinges at the bottom (that is, below 6:00 and where the bezel meets the main case body)? I suspect that you won't, as double-hinged cases are usually associated with an older style of pocket watch, but it's worth checking. If you do see little hinges for the FRONT (it's more likely that the back will be hinged), then look for a little lip on the bezel that's used to pry open the front. Pull on that to open the case.
If you don't see hinges, which is what I expect, your front bezel unscrews. You can try to do this with your bare hands, but it's a lot easier if you have a bit of "gripping" rubber so your hands don't slip so badly. I have a small rectangle of shelf non-slip stuff that works perfectly for this. Turn the bezel counterclockwise. It may resist a little bit at first due to accumulated dirt, but then it should easily screw off.
Once you have the bezel away from the face, look closely at about 2:00 on the watch dial. Just at the edge of the dial, you should see a little lever or button. GENTLY pull this away from the watch face until it stops. Now, when you turn the winding crown, you should be able to set the time. Once the time is set, gently push the lever back to its prior position. Now, you should be able to wind the watch without changing the time.
Be very careful when screwing the bezel back onto the watch body. These parts typically have very fine threads, and it's easy to cross-thread the pieces. Don't force the two pieces together; once the threads catch properly, the front bezel will screw on easily without resistance.
An older style of pocket watch required the use of a little key to set the time from the back of the pocket watch movement. However, these watches were also wound by the same key, so the fact that you're able to wind this watch with a crown suggests to me that your watch doesn't use this system.
May 27, 2011 • Watches
How to change battery on a ladies classic 18 k and steel watch with solid back
Welcome to Fixya,
Hi hope this steps will helped you in changing the battery but I just want you to remind that you have to be careful in changing the battery because it might affect the other part.
1- remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
2- remove all 5 gold bezel screws
3 - be careful,, the bezel/crystal will pry off easy
4 - be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
5 - small screwdriver and remove/replace battery
6 - reinstall watch guts/bezel and gold screws
7 - push crown back into watch
Thank you for using Fixya.
My Lady Ambassador watch stops every night between 11:45 and midnight (I do not sleep with it on.) In the morning, I reset it and it runs fine - until night time. The watch is less than a year old.
Does your watch have a date change?
The date usually changes about this time and it could be this that is stopping it working. Having it serviced could solve the problem, it it hasn't had any attention for a long time.
4helpful
I can't pull the bezel out to change the time on this watch! Help
The bezel is metal ring surrounding the crystal. What you can not pull out is called CROWN. Unscrew it first and then pull out.
How do I set the time on my women's Locman titanio tonneau watch?
It looks like you've been pulling the crown halfway only.
When you pull out crown to the first click - watch is in day/date setting mode.
When you pull the crown further out (second click) - watch is in time setting mode.
1helpful
What are the dials? How do you set knobs? Can't move center knob.
The 3 dials are the chronograph for timing an event such as motor racing(a stop watch). The centre know (the crown) has to be unscrewned counter clockwise and then pulled out from the case at, first stage will allow changes to date, second to set the time.
The outside bezel is used as a means of measuring time, eg. 20min, from a random starting point and is often used for 'oxygen' time for diving.
How is time and date adjusted
If the details says "stationary" then this means that the bezel does not move. This is typical in an inexpensive watch such as Nautica, and is probably just for "looks".
3helpful
Tag Heuer Ladies Professoinal 2000
Hi Dude, it's one of those things your going to cuss once you know. Just unscrew the Bezel.Thats it. Steve
10helpful
Timex Indiglo Acqua watch
For analog Acqua watches adjust date when month has less than 31 days:
3-Position Crown: Pull crown to "MIDDLE" position and turn CLOCKWISE or
COUNTERCLOCKWISE until correct date appears.
2-Position Crown: Pull crown to "OUT" position and turn CLOCKWISE until date
changes (approx.1:00 a.m.). Then turn COUNTERCLOCKWISE to 7:30 p.m. Repeat until correct date appears.
Dec 05, 2007 • Watches
12helpful
4answers
Ebel Classic Wave fitting a new crown
i have changed the battery on my and my wifes ebel classic wave watch,,
step 1 ...remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
step 2 ...remove all 5 gold bezel screws
step 3... be careful,, the bezel/crystal will pry off easy
step 4... be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
step 5.. small screwdriver and remove/replace battery
step 6... reinstall watch guts/bezel and gold screws
step 7... push crown back into watch
step 8... take wife and kids to dinner ,,you just saved three hunderd bucks
if have done it many times ,, you can do it !!!!
Top Swiss Army Wenger Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Swiss Army Wenger Watch Expert? Answer questions, earn points and help others
