~Connect the TI Connectivity cable between the PC and the calculator.
~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
~Follow the on-screen directions to reinstall the calculator's OS. When or, if the calculator install the fresh OS goto step 4.
Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
If the above process did not work. Try re-doing the procedure and, extend the time in step 4 by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
Now just in case this calculator wasn't posted correctly. Here's my instructions for a Ti 83 that won't turn on. This is not the same procedure that the Ti 83 Plus has.
Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary. And of course if the calculator does not turn on, I re-do the procedure and, increase the amount of time by 5 minutes to ten minutes that all the batteries are removed.
~Connect the TI Connectivity cable between the PC and the calculator if you haven't already.
If the above process did not work to turn your calculator on, try re-doing the above process. Next time extend the time in step 4 by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
Just keep trying. Sometimes they can be a pain.
