Hello Timothy, the microphone has a 3.5 mm connector, which has a thread, you must unscrew this thread and you should be able to exit
Discuss the type of connector you have
I hope you can solve the problem
Greetings Franco Dosil
Hola Timothy, el microfono tiene un conector de 3,5 mm, que tiene una rosca , debes desenroscar esta rosca y tendria que poder salir
Comenta el tipo de conector tiene
Espero puedas resolver el problema
Saludos Franco Dosil
https://assets.sennheiser.com/global-downloads/file/8949/SK_100_G3_Manual_12_2016_EN.pdf
SOURCE: How do you troubleshoot phasing issues with the
Phasing issues? Not sure what you mean by phasing. Phasing would be the phase of the audio pressure on the mic versus the electrical phase out of the receiver. DO NOT EXPECT the phase to be stable in any way as there is a communication and data conversion in the loop. The phase will be highly audio frequency dependent as well.
