HP Officejet 4215v All-in-One Printer Logo
Anonymous Posted on Aug 11, 2009
Error:0xf0af8005 - HP Officejet 4215v All-in-One Printer
Anonymous
Level 3:
President:
  • Master 2,777 Answers
  • Posted on Aug 11, 2009
Anonymous
Master
Level 3:
President:
Answers
2777
Questions
0
Helped
666327
Points
9584
That error indicates a power supply problem internally in the unit. You will need to call HP at 800-474-6836 to obtain the replacement part or get it replaced free under warranty.
Testimonial: "This was great and fast. Thanks so much for the help"
1helpful
Hp office jet 4255 all in one ( error 0xf0af800)
Trata de bajar el nuevo driver directamente de HP e instala tu impresora otra vez. Muchas veces eso resuelve el problema
Error 0xf0af8005 appears on the screen
I have the same problem after a nearby lightning strike. I think something got fried.
Error message 0xf0af8005 and green and orange flashing lights
Please follow these instructions to reset the printer. If that doesn't work, try again but wait longer before reconnecting. Otherwise, here's the home support page for your machine. You can look up the meaning of the flashing lights there as well.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
3helpful
2answers
ERROR :0xf0af8005
Solution one: Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 1: Example USB connection (your product might not look exactly the same as this example) c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the ' Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
17helpful
3answers
Error code i hp 4255 officejet printer
have problem in my printer hp officejet 4255 oll-in-one it give message ERROR : 0XF0aF8005 pleas help me I can repair the priter if u can diagnose the error code
OJ 4255
With that error code, I would assume the modem is dead. You could try to get it repaired, but it would probably be cheaper just to buy another unit.
Troubleshooting information about "fatal error" and "MSI.ojj4500
sirs, i own a hp office jet 4215 all in one when i try to on the printer the on light and orange colour! this light flickers and the message on screen says " error : 0xf0af8005 can you please help to solve this problem. thanks ben.
1helpful
ERROR PROBLEM
I have the same issue. Error:0xf0af8005. I found on another site that it is a hardware issue and would cost $150 to fix. Cheaper to buy another PC...
2helpful
2answers
Error: 0xf0af8005
Hi ,
This error relates to hardware problem.. i never faced this problem but heard lot of users talking about it .. as per HP techies it takes close to 150$ to recitify the problem which is almost a cost of new printer...
Would recoment to contact hardware manufacturer if the product is still under warranty....
Please let me know if this post was usefull..
Thanks...robosoft..
k24674
Grand Canyon Tech
Grand Canyon Tech
