I have a whirlpool self cleaning oven and can not removebulb, it just moves back and forth. Please tell me how to remove cover to get to the bulb to replace,
I had similar difficulty. This worked for me after 45 mins grief.
I got a heavy duty 1cm wide elastic band (length double was about 14-15cm). This is a common size heavy duty elastic band in the UK.
This elastic band is much too long to go around the glass bulb cover so I tied a knot in it so that i had a complete circle of rubber band tightly held around the bulb cover. Then I used a Mole wrench -a kind of large adjustable spanner - to undo the glass bulb cover. It came off easily because the rubber band gave sufficient grip to undo it. It is about 2.5 full turns anticlockwise to completely free it.
I hope this will help the next viewer of this website.
Geoff
I had same grief for 45 mins. It unscrews anticlockwise about 2 full 360 degree turns but is "baked in" and can't usually be turned by hand.. Once removed, there is a bulb inside that will easily unswrew with your fingers.
In order to actually get the bulb cover to turn, I used a rubber band 1cm wide and 14cm long when double. A common heavy duty rubber band i the UK. This is too long to wrap around the glass bulb holder to provide a grip surface for an adjustable spanner or, as I used, a Mole wrench. So I tied a knot in it to make a shorter loop. Ensure it is a pretty tight fit around the bulb holder and won't slip easily. The cover came undone as easy as anything.
Hope this helps someone. This is a great site and I thought of my idea from Fixya answer saying try wearing rubber gloves.
WhiteGodo
Try something like a
Baby Boa Strap Wrench
they are available everywhere all the normal online sites and they have a million uses
Preheat oven to 350 degrees put on gloves and turn to the left 2 turns making sure you dont touch the top oven coils
can not remove bulb cover in a whirlpool gas stove
